Forum Newbie
Last Login: 9/6/2006 9:00:57 PM
Visits: 58
I would like to use the right angle attachment with a sanding band. However, as shown in the attached photo, the band does not clear the attachment head when pressed to the wall.
Would a flap wheel work is this case? Is a sanding attachment available that I can draw down a wall to sand imperfections?
Supreme Being
Last Login: 1/18/2009 1:14:25 AM
Visits: 932
| flapwheels would work but I think the contour sander would work better in this applaction
Supreme Being
Last Login: 9/23/2007 1:01:15 AM
Visits: 254
I agree with cagb. You need a different kind of sander in that situation. The contour sander will work or you might just hand sand it.
my 2 cents......
RANIE
Forum Newbie
Visits: 58
| I need to sand a long 1/2 inch seam down the wall. I could hand sand, but it would be so much easier with POWER. Does Dremel or anyone else make a flap wheel with a big enough diameter to clear the right angle adapter?
Supreme Being
Visits: 932
| The flap wheel has a diamenter of 1 in and should clear the right angle tool
