Cutting Lines in mylar for boat station patterns
Author
Message
sdenaultca
View Quick Profile
Junior Member
Junior Member (19 reputation)Junior Member (19 reputation)Junior Member (19 reputation)Junior Member (19 reputation)Junior Member (19 reputation)Junior Member (19 reputation)Junior Member (19 reputation)Junior Member (19 reputation)Junior Member (19 reputation)
Last Active: 5 Years Ago
Posts: 1, Visits: 3
Never used a Dremel tool before and want to us it to cut lines in mylar. I have transferred canoe station/mold lines onto mylar. Now I want to cut out the line giving me a simple way to repeatedly trace the mold shape onto plywood.
The reason for taking the time to cut the lines into mylar is I plan to make several of the same canoe.
What I need to do is use the Dremel tool and presumably a 1/16" rotorotary to cut a slot into the mylar where the marker line is now.
This opening will allow me to insert a pencil or marker tip into the slot created and trace my shape/pattern onto plywood.
What is the best method for using the Dremel tool for a cutting tool in this kind of situation.
SD
Beth at Dremel
View Quick Profile
Supreme Being
Supreme Being (5.5K reputation)Supreme Being (5.5K reputation)Supreme Being (5.5K reputation)Supreme Being (5.5K reputation)Supreme Being (5.5K reputation)Supreme Being (5.5K reputation)Supreme Being (5.5K reputation)Supreme Being (5.5K reputation)Supreme Being (5.5K reputation)
Group: Administrators
Last Active: 4 Years Ago
Posts: 229, Visits: 4.3K
****o, I just wanted to apologize to you for not getting back more readily to your question.  We were having some technical difficulty with our site.  In regards to your mylar question, I have to honestly admit that the only mylar I know of is the thin and filmy type (like on balloons), however, if yours is a "thicker" type mylar, then you should be able to use one of our bits from our "Carving/Engraving" selection.  We make some "very small" tipped ones, which are from #105 - #113.  These are for detail engraving, carving, and routing in wood, fiberglass, plastic and soft metals.  We also do have larger ones and the best one for "slotting" would be #199 which is 3/8" across.  Now, if you otherwise just prefer to use a "Cut-off Wheel" and literally "drag" it through the wood partially (not going all the way through), that should work for you as well.  Do remember though, with a "wheel", it really can only go straight or angles, no curves.  To view these bits, please visit our website at www.dremel.com.  Should you have any further questions, you can now find a "Live Chat" on our website or you can call one of our representatives at Dremel on our toll free phone number of 1-800-437-3635, Monday-Friday, 8:00 am - 6:00 pm, CST.
-Beth at Dremel
Reading This Topic
