Dremel Message Board
Dremel 400 XPR Series vs. Craftsman rotary... Expand / Collapse
Author
Message
Posted 11/22/2006 5:15:55 PM
Forum Newbie
Last Login: 11/22/2006 5:20:54 PM
Posts: 5, Visits: 5
The new 400 XPR Dremel is amazing!! it has a 2 amp. motor power, variable velocity 0 - 35000 rpm.
    But, I have also the Craftsman rotary tool . It has the exacly same specifications than the 400 XPR, the same line and all the Dremel  attachments and accesories are compatibles. So Craftsman rotary tool is a good option also.
Don´t you think ??
HELP!! Hi, I´m looking for some new carbon brushes to my 400 Series XPR rotary tool, but i can`t find the part number from that piece. How do I have to order it? Is it available? How realy long life has the carbon brush with continue use?
Thank`s.
BowHunter
Post #1300
Posted 11/23/2006 11:39:47 PM
Forum Newbie
Last Login: 12/21/2006 9:38:33 AM
Posts: 4, Visits: 11
BowHunter... check out this link to the Dremel page.   This should be the part you are looking for:
http://www.dremel.com/en-us/attachments-and-accessories/attachment-accessory-detail.htm?H=188575&G=66433&I=69818
'says it's part #2610921562 Carbon Motor Brush
lovin' the  400
(yes, this be the same reply I left on the topic started by
Post #1311
Posted 11/28/2006 6:03:52 PM
Forum Newbie
Last Login: 11/28/2006 5:45:14 PM
Posts: 3, Visits: 5
Does Dremel have a cutting bit comparable to the Craftsman Drywall Guide Point Bit? The bit has a guide point tip for controlled cuts around outlet boxes.
Post #1320
Posted 12/1/2006 10:39:40 AM
Supreme Being
Last Login: 10/7/2011 3:25:29 PM
Posts: 160, Visits: 273
Should be the same since the rotary craftsmen is made by Dremel. Sears just slaps their label on the ones Dremel makes for them.
TDL
Post #1335
Posted 12/14/2006 7:02:00 AM
Supreme Being
Last Login: 9/23/2007 1:01:15 AM
Posts: 115, Visits: 254
Yes, In fact Dremel has 2, the 560 drywall cutting bit and the 561 multi purpose cutting bit. It was a standard accessory for the now retired Dremel Advantage Saw
my 2 cents......
RANIE
Post #1386
« Prev Topic | Next Topic »
Forum Moderators: John, Dremel Customer Service
Permissions Expand / Collapse
All times are GMT -6:00, Time now is 8:00pm
Execution: 0.031. 9 queries. Compression Disabled.
