Dremel 400 XPR Series vs. Craftsman rotary tool
Author
Message
BowHunter
View Quick Profile
Supreme Being
Supreme Being (185 reputation)Supreme Being (185 reputation)Supreme Being (185 reputation)Supreme Being (185 reputation)Supreme Being (185 reputation)Supreme Being (185 reputation)Supreme Being (185 reputation)Supreme Being (185 reputation)Supreme Being (185 reputation)
Last Active: 13 Years Ago
Posts: 5, Visits: 5
The new 400 XPR Dremel is amazing!! it has a 2 amp. motor power, variable velocity 0 - 35000 rpm.
    But, I have also the Craftsman rotary tool . It has the exacly same specifications than the 400 XPR, the same line and all the Dremel  attachments and accesories are compatibles. So Craftsman rotary tool is a good option also.
Don´t you think ??
HELP!! Hi, I´m looking for some new carbon brushes to my 400 Series XPR rotary tool, but i can`t find the part number from that piece. How do I have to order it? Is it available? How realy long life has the carbon brush with continue use?
Thank`s.
BowHunter
bilbo1969
View Quick Profile
Supreme Being
Supreme Being (128 reputation)Supreme Being (128 reputation)Supreme Being (128 reputation)Supreme Being (128 reputation)Supreme Being (128 reputation)Supreme Being (128 reputation)Supreme Being (128 reputation)Supreme Being (128 reputation)Supreme Being (128 reputation)
Posts: 4, Visits: 11
BowHunter... check out this link to the Dremel page.   This should be the part you are looking for:
http://www.dremel.com/en-us/attachments-and-accessories/attachment-accessory-detail.htm?H=188575&G=66433&I=69818
'says it's part #2610921562 Carbon Motor Brush
lovin' the  400
(yes, this be the same reply I left on the topic started by
spwilkins
View Quick Profile
Forum Guru
Forum Guru (69 reputation)Forum Guru (69 reputation)Forum Guru (69 reputation)Forum Guru (69 reputation)Forum Guru (69 reputation)Forum Guru (69 reputation)Forum Guru (69 reputation)Forum Guru (69 reputation)Forum Guru (69 reputation)
Posts: 3, Visits: 5
Does Dremel have a cutting bit comparable to the Craftsman Drywall Guide Point Bit? The bit has a guide point tip for controlled cuts around outlet boxes.
the Dremel Lady
View Quick Profile
Supreme Being
Supreme Being (2.9K reputation)Supreme Being (2.9K reputation)Supreme Being (2.9K reputation)Supreme Being (2.9K reputation)Supreme Being (2.9K reputation)Supreme Being (2.9K reputation)Supreme Being (2.9K reputation)Supreme Being (2.9K reputation)Supreme Being (2.9K reputation)
Last Active: 8 Years Ago
Posts: 160, Visits: 273
Should be the same since the rotary craftsmen is made by Dremel. Sears just slaps their label on the ones Dremel makes for them.
TDL
ranie
View Quick Profile
Supreme Being
Supreme Being (2.3K reputation)Supreme Being (2.3K reputation)Supreme Being (2.3K reputation)Supreme Being (2.3K reputation)Supreme Being (2.3K reputation)Supreme Being (2.3K reputation)Supreme Being (2.3K reputation)Supreme Being (2.3K reputation)Supreme Being (2.3K reputation)
Last Active: 5 Years Ago
Posts: 115, Visits: 255
Yes, In fact Dremel has 2, the 560 drywall cutting bit and the 561 multi purpose cutting bit. It was a standard accessory for the now retired Dremel Advantage Saw
my 2 cents......Wink
RANIE
Reading This Topic
