285MultiPro used as dremel
Author
Message
Manchild
View Quick Profile
Supreme Being
Supreme Being (84 reputation)Supreme Being (84 reputation)Supreme Being (84 reputation)Supreme Being (84 reputation)Supreme Being (84 reputation)Supreme Being (84 reputation)Supreme Being (84 reputation)Supreme Being (84 reputation)Supreme Being (84 reputation)
Last Active: 12 Years Ago
Posts: 2, Visits: 3
I was wondering if I could use my model 285MultiPro as a dremel to cut out the recessed part for the strike plate in a door. Using a chisel has never been good for me so I wanted to set the depth and cut out where the strike plate goes by hand? And if possible to do this, what dremel and accessories would I need for this job?
the Dremel Lady
View Quick Profile
Supreme Being
Supreme Being (2.9K reputation)Supreme Being (2.9K reputation)Supreme Being (2.9K reputation)Supreme Being (2.9K reputation)Supreme Being (2.9K reputation)Supreme Being (2.9K reputation)Supreme Being (2.9K reputation)Supreme Being (2.9K reputation)Supreme Being (2.9K reputation)
Last Active: 8 Years Ago
Posts: 160, Visits: 273
The multipro IS a dremel so I'm not sure I understand you saying you want to use it AS a dremel when it is one. Yours is the two speed, correct? That said, you can use the router attachment or even the 565 guide with a router bit, 650,653 or 654 to remove most of the wood and then if necessary free hand with a high speed cutter that has a point to it or chisel out the corners if you don't want them rounded.
TDL
the Dremel Lady
View Quick Profile
Supreme Being
652, not 653, typo - sorry
TDL
Manchild
View Quick Profile
Supreme Being
Posts: 2, Visits: 3
Thanks for the response. Yes, I wanted to use my dremel as a router. The one I own has the variable speed control. Looks like the 565 you suggested would be perfect for my door plate. Thanks for the help.
Reading This Topic
