Speed control and other issues
Author
Message
elcam84
View Quick Profile
Supreme Being
Supreme Being (162 reputation)Supreme Being (162 reputation)Supreme Being (162 reputation)Supreme Being (162 reputation)Supreme Being (162 reputation)Supreme Being (162 reputation)Supreme Being (162 reputation)Supreme Being (162 reputation)Supreme Being (162 reputation)
Last Active: 12 Years Ago
Posts: 6, Visits: 15
I have an old (I'm told when I called for parts) dremel. It's a 395 type 3.
The little rubber coupler in it decintegrated again. This rubber spacer is a very bad idea.
Also the bearings in the little stub shaft are really worn out. Actually They were pretty sloppy from day one when it was new.
I replaced the speed control a few years ago in it too. The little board in it broke in half.
One major improvement in the dremel would be a real speed control. It would be very nice if it had the circuitry to maintain a constant speed.
I don't know if the 400 has this or not. From reading the info it doesn't.
Also a better designed impeller would make the tool much quieter and improve airflow. Instead of a no engineering required straight vane fan. It only takes a few minutes to draw the straight one in cad and just a fraction longer to make it a better design.
Reading This Topic
