USING CUTOFF WHEELS ON STAINLESS STEEL
Author
Message
notacks
View Quick Profile
Forum Guru
Forum Guru (57 reputation)Forum Guru (57 reputation)Forum Guru (57 reputation)Forum Guru (57 reputation)Forum Guru (57 reputation)Forum Guru (57 reputation)Forum Guru (57 reputation)Forum Guru (57 reputation)Forum Guru (57 reputation)
Last Active: 12 Years Ago
Posts: 1, Visits: 29
Ive always used a sawzall for cutting stainless steel bolts..But I had a situation recently where I had to cut out the pads under my engine mounts in my boat to replace the waterlogged wood underneath..
After using the cutoff wheel on the fiberglass,I looked to the rear of the boat and there was 6 stainless steel bolts sticking out of the transom that hold the swim platform on..These would be very hard to cut off with a sawzall because I could damage the fiberglass inside the boat...Well I gotta say that my new dremel tool not only cut those bolts in 1/8 of the time it takes a sawzall,It also left a nice clean cut and no damage to any fiberglass..I honestly dont know why I havent bought one of these years ago...HOO-RAH  DREMEL...
JackOfAllTrades
View Quick Profile
Supreme Being
Supreme Being (261 reputation)Supreme Being (261 reputation)Supreme Being (261 reputation)Supreme Being (261 reputation)Supreme Being (261 reputation)Supreme Being (261 reputation)Supreme Being (261 reputation)Supreme Being (261 reputation)Supreme Being (261 reputation)
Last Active: 10 Years Ago
Posts: 9, Visits: 31
[b]notacks (2/28/2007)[
Which 'Cut off' wheel did you use ? Please indicate the number. Thanks.
SpiderCurt
View Quick Profile
Supreme Being
Supreme Being (4K reputation)Supreme Being (4K reputation)Supreme Being (4K reputation)Supreme Being (4K reputation)Supreme Being (4K reputation)Supreme Being (4K reputation)Supreme Being (4K reputation)Supreme Being (4K reputation)Supreme Being (4K reputation)
Last Active: 6 Years Ago
Posts: 213, Visits: 660
Hi JackOfAllTrades
Since this is the "New EZ Lock Accessory" forum, I would assume that Notacks is using the EZ Lock cut off wheels. I prefer to use the reinforced cut off wheels as these are not as easily broken and those that came in the EZ Lock Kit I purchased are the reinforced kind and have provided the best service to date as far as cut off wheels go.
Curt
JackOfAllTrades
View Quick Profile
Supreme Being
SpiderCurt (2/26/2009)
Hi JackOfAllTrades
Curt,
I presume you are referring to EZ 456 and EZ 409.
Diverting somewhat, there appears to conflicting opinions on the uses of the EZ 545 Diamond wheel. Can this be used to cut steel and stainless steel? I do not want experiment with it as it is rather costly and I do not want to damage the wheel. Unsure The EZ series is not covered in the 'Instructional safety manual' of the Dremel 300. I would like to know what this can be used for and what it should NOT be used for. Smile
Pl excuse my ignorance.
Jack.
Dremyfan
View Quick Profile
Supreme Being
Supreme Being (4.4K reputation)Supreme Being (4.4K reputation)Supreme Being (4.4K reputation)Supreme Being (4.4K reputation)Supreme Being (4.4K reputation)Supreme Being (4.4K reputation)Supreme Being (4.4K reputation)Supreme Being (4.4K reputation)Supreme Being (4.4K reputation)
Last Active: 5 Years Ago
Posts: 225, Visits: 412
This does not answer all your question, JackOfAllTrades, however it positively answers part of it in Customer Service>FAQ's:
Plastic
Q: What will work to cut plastic?
A: This will depend on how thick the plastic is. A cut-off wheel will cut plastic PVC. The diamond wheel (#545) will also easily cut it. If the application is actually cutting through a piece of plastic, it is important to use a cutter or cutting wheel that will get through the thickness of plastic. Otherwise, you will have to cut the plastic from both directions which can mean a very sloppy cut.
I'll try to gather more info on the rest and let you know
Enrique
Dremyfan
View Quick Profile
Supreme Being
I guess this link into Dremel Attachments&Accesories will answer your question:
http://www.dremel.com/en-us/AttachmentsAndAccessories/Pages/AttachmentsDetail.aspx?pid=EZ545
I suggest you make a tour through all this Dremel site using the above buttons. You will find very interesting reading material. Good luck.
Enrique
JackOfAllTrades
View Quick Profile
Supreme Being
Dremyfan (3/1/2009)
I guess this link into Dremel Attachments&Accessories will answer your question:
Hi Enrique,
Thanks.
The above page (EZ545) does not open due to an error.
However There is no problem with the following page
http://www.dremel.com/en-us/AttachmentsAndAccessories/Pages/AttachmentsDetail.aspx?pid=545
For the benefit of other viewers i have copied below an extract from this page. It seems that the 545 cannot be used to cut steel.
"The 545 Diamond Wheel is completely coated with fine diamond particles for working with hard materials. Designed to be long lasting and not lose its shape or break, it provides smooth, fine cuts. Great for cutting, sawing and carving of hard materials, such as marble, concrete, brick, porcelain, ceramics, hard epoxy and soft and hard wood."
JackOfAllTrades
View Quick Profile
Supreme Being
Hi Enrique,
I managed to open the following page:
http://www.dremel.com/en-us/AttachmentsAndAccessories/Pages/AttachmentsDetail.aspx?pid=EZ545[/url]
EZ545 EZ Lock 1-1/2" Diamond Wheel
Under the 'features' tab, it shows:-
Material : For Cutting Metal
Unfortunately it does not state the type of metal that it can cut.
It seems that EZ545 differs from the 545 although both are diamond coated wheels.
I would like have the views of anyone with practical experience with these wheels.
Dremyfan
View Quick Profile
Supreme Being
Yes, that's best. Please share your information with us if you get from somewhere else. Thanks
Enrique
testes eroded in sinus
View Quick Profile
Forum Member
Forum Member (49 reputation)Forum Member (49 reputation)Forum Member (49 reputation)Forum Member (49 reputation)Forum Member (49 reputation)Forum Member (49 reputation)Forum Member (49 reputation)Forum Member (49 reputation)Forum Member (49 reputation)
Last Active: 9 Years Ago
Posts: 1, Visits: 12
Do these bits, wheels if you will work with other rotary tools too?
Does anybody know?
I have a jobmate. It's a Canadian brand and I'm looking for a strong cut-off wheel to cut stainless steel [fretwires].
Thanks if you can help.
Reading This Topic
