Dremel Message Board
newbie wanting to cut pyramids Expand / Collapse
Author
Message
Posted 3/25/2007 10:59:24 PM
Forum Newbie
Last Login: 3/26/2007 10:10:38 PM
Posts: 2, Visits: 5
Greetings all.
I was wondering if anyone has tried such a thing, and if so, which attachment did you use, any tricks you might pass on? I want these to be about 1-2" square on the base, and equilateral.
Thanks
Adam Smith
Post #1804
Posted 3/26/2007 1:43:13 PM
Supreme Being
Last Login: 3/8/2010 11:40:36 AM
Posts: 214, Visits: 5,068
I hate to say it, but the Dremel may not be practical here.  Don't get me wrong, I am a big time Dremel Fan!   I would start with a 2" square block.  Sand each side down, a little at a time, rotating the block one way, sanding the piece of wood at the same angle, so that all of the sides are uniform.
When you are finished, you should be pretty close to your desired dimensions.
Good Luck!
Barry C.
If you live to love, then you'll love to live!
Post #1810
Posted 3/26/2007 10:13:36 PM
Forum Newbie
Posts: 2, Visits: 5
Thanks for the reply. You may be right. I may have to find another way to do it, because I need a whole bunch of them.
Adam Smith
Post #1811
Posted 3/27/2007 7:35:57 AM
Supreme Being
Last Login: Yesterday @ 1:02:04 PM
Posts: 1,176, Visits: 4,682
If you had a Dremel Scroll saw it would work good for that if not you could use a band saw and a fixed belt sander or disk sander. The scroll saw or band saw could cut the shape out roughly and then sand to finish.
Doug
Post #1812
Posted 4/3/2007 7:42:21 AM
Junior Member
Junior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior Member
Last Login: 8/14/2008 7:36:24 PM
Posts: 11, Visits: 71
Assuming you have a table saw, you might consider investing in a sanding disc for your saw.  I bought a Craftsman 10 inch sanding disc for my Jet table saw.  The disc is very thick steel with sandpaper glued to both sides.  Two different grits.  Anyway, the disc obviously replaces your saw blade.  You can use your mitre gauge to position the pieces.  Sands real fast, too.  The thick steel plate prevents the disc from flexing and you're turning at about 6,000 RPM.  I think I spent about $16 on this rascal and I've used it a lot.  Good luck.
Post #1852
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -6:00, Time now is 3:12am
Powered by InstantForum.NET v4.1.4 © 2010
Execution: 0.250. 9 queries. Compression Disabled.
