Dremel Message Board
Hex Collet & More Expand / Collapse
Author
Message
Posted 5/25/2007 3:27:47 PM
Forum Guru
Forum GuruForum GuruForum GuruForum GuruForum GuruForum GuruForum GuruForum Guru
Last Login: 11/13/2008 1:54:14 PM
Posts: 52, Visits: 260
Hex Shank bits of various types are available easily, including ones with various size drill bits embedded. A collet to take a standard hex bit would be a very welcome accessory for the Dremel.
I have 3 Dremels, and many accessories. It is sometimes frustrating to find the accessory will not work with the Dremel most appropriate for the job.
For example the Dremellite is great for use in awkward places, where normal light is poor, (under the sink for example). The ideal Dremel for this is the cordless Lithium Ion one, but the Dremel light will not fit on this. A correct size washer would do the job.
Also accessories like the Jig Saw and Planer attachment would be great if they worked with the cordless model for convenience - it is a bit of a wire tangle to get the corded Dremel to that warped door on the terrace ! It would be ideal if every accessory worked with every model.
Post #2136
« Prev Topic | Next Topic »
Forum Moderators: John
Permissions Expand / Collapse
All times are GMT -6:00, Time now is 8:03pm
Powered by InstantForum.NET v4.1.4 © 2009
Execution: 0.312. 17 queries. Compression Disabled.
