Dremel Message Board
cuuting 1/2 inch wood? Expand / Collapse
Author
Message
Posted 6/30/2007 4:43:38 AM
Forum Newbie
Last Login: 7/1/2007 2:32:32 PM
Posts: 4, Visits: 4
Can I use my dremel to cut a heart or oval shape through a 1/2 inch piece of wood about two inches wide? If this is possible what attachment or bit should I use and how should I cut it?
Post #2341
Posted 6/30/2007 2:49:38 PM
Forum Guru
Forum GuruForum GuruForum GuruForum GuruForum GuruForum GuruForum GuruForum Guru
Last Login: 11/13/2008 1:54:14 PM
Posts: 52, Visits: 260
the Dremel Multisaw (Jigsaw) attachment does a fine job on soft wood. It will work with the Dremel 400/398 - don't know about other Dremel models.
Sam
Post #2344
Posted 6/30/2007 3:18:20 PM
Forum Newbie
Posts: 4, Visits: 4
Sadly I have the 300 series so I guess I'll just have to try using a cutting bit and see how it goes.
Post #2345
Posted 6/30/2007 3:27:29 PM
Supreme Being
Last Login: Yesterday @ 6:56:30 PM
Posts: 936, Visits: 3,929
If you use the Multipurpose Cutting Kit Model #565 and take your time you should have no problem. Practice first till your comfortable with it.
Doug
Post #2346
Posted 7/1/2007 2:34:53 PM
Forum Newbie
Posts: 4, Visits: 4
I started cutting yesterday but I started burning the wood.  I guess that means I should turn the speed down but that goes slow.  I think i'll be able to make a rough outline of the shape i want and then sand it down to get the exact shape.
Post #2350
Posted 7/1/2007 3:09:57 PM
Supreme Being
Check to make sure that the wood is not pileing up behind the cutter you have to keep the area behind the cutter clean.
Doug
Post #2351
Posted 7/6/2007 7:43:08 PM
Supreme Being
Last Login: 1/4/2009 3:45:29 PM
Posts: 210, Visits: 5,041
Take your time.  You are right, if you are burning the wood, then slow down.  Keep the cutting area clear like Doug suggested.
the other reason why you want to go slow is so that you won't burn out, or break the cutting bit.
When you are ready to sand the shape, I would recommend you mount the Dremel into the 231 table, with a fine sanding drum on it.  You can slide and move the working piece around the sanding drum very easily.
Goodluck, Barry.
If you live to love, then you'll love to live!
Post #2379
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -6:00, Time now is 6:29am
Powered by InstantForum.NET v4.1.4 © 2009
Execution: 0.250. 16 queries. Compression Disabled.
