Forum Newbie
Last Login: 9/16/2007 11:52:03 PM
Visits: 6
The rotozip is a semi useful item.
It looks just like aa 1/8in. drill bit but in fact has spiraling cutting edge along the length. Would this be to much for the dremels top bearing?
Could I use the roto to cut out panels of inch thick fiberglass?
Is this a viable tool for enlarging or reaming a drilled hole in aluminum?
Is anyone doing this?
DIY is loveing deeply
Supreme Being
Last Login: Today @ 6:55:51 AM
Visits: 4,676
I believe that bit should cut fiberglass I was looking at the #561 bit for the multi-purpose cutter for the Dremel and it says it will cut fiberglass so I would give it a try. I worked in a boat factory for about 4 years and we used Jigsaws with wood or metel blades I think the metel cutting blades done the best. Well I'm rambling try the bit it should do the job.
Doug
