Dremel Message Board
«««123
What all do you make with your dremel tool? Expand / Collapse
Author
Message
Posted 6/18/2008 11:43:02 AM
Supreme Being
Last Login: 9/7/2009 3:18:23 AM
Posts: 210, Visits: 607
Originally, I used the Dremel to assist in my computer business when rebuilding a computer. The proprietary configurations of the mother board input/output connections made it necessary to modify the chassis back panel in order to accept a replacement board. Over time this has changed and new boards come with back panel inserts which will fit standardized cases. While not the problem it once was, I still need to do some chassis modifying on occasion, particularly when replacing power supplies in certain branded machines.
I received my present Dremel 400XPR as a Christmas present. It came in a kit with a much wider variety of bits and other accessories than I had kept previously. As a result, I started using the Dremel for whatever came along.
Since the Dremel has been added to the tool box of most every member of the case modifier sub-culture, my original use of the tool is not uncommon. There are many case-mod web sites that host Dremel "how-to's", although many use the Dremel for cutting holes in case panels for side windows they also demonstrate etching/engraving as well.
Curt
Curt
My Web Site
Post #3958
Posted 7/4/2008 5:30:40 PM
Junior Member
Junior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior Member
Last Login: 2/24/2009 7:37:19 PM
Posts: 13, Visits: 22
I like to make small boxes and small decorative birdhouses. The wood always splits when I drive a nail directly into the wood. I put a small collet in my Dremel multi speed 395 and put a large straight needle in the collet. Before I drive any nails I run the running Dremel with the needle in it into the wood and then drive the nail. The wood never splits anymore and the nails never bend. Just be careful when using the needle. It will burn the wood somewhat.
Post #4082
Posted 8/24/2008 6:47:22 PM
Forum Newbie
Last Login: 8/24/2008 9:30:31 PM
Posts: 3, Visits: 18
i recently finished an arcade stick. used the dremel for routing (with the router attachment).
most the dremel work can be seen here: http://dfyb.wordpress.com/2008/06/24/arcade-stick-and-buttons-installed/
Post #4373
Posted 8/24/2008 8:35:40 PM
Supreme Being
Last Login: 8/1/2009 9:35:07 AM
Posts: 96, Visits: 362
That looks great. I just ordered the plunge router from a nearby home center today. Seeing your project helps confirm my decision. Thank you.
Thanks,
Kurgan
Post #4376
Posted 11/12/2009 5:05:12 PM
Forum Member
Forum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum Member
Last Login: Today @ 12:28:59 PM
Posts: 47, Visits: 64
Fish and Birds!!
"For almost every problem,
there is a DREMEL solution"
"When all else fails, read the instructions."
Jim
Post #6215
« Prev Topic | Next Topic »
«««123
Active Users: 1 (1 guest, 0 members, 0 anonymous members)
Permissions Expand / Collapse
All times are GMT -6:00, Time now is 10:56pm
Powered by InstantForum.NET v4.1.4 © 2009
Execution: 0.047. 8 queries. Compression Disabled.
