is the 3000 strong enough for stone carvings?
Author
Message
craiganater
View Quick Profile
Forum Member
Forum Member (25 reputation)Forum Member (25 reputation)Forum Member (25 reputation)Forum Member (25 reputation)Forum Member (25 reputation)Forum Member (25 reputation)Forum Member (25 reputation)Forum Member (25 reputation)Forum Member (25 reputation)
Last Active: 5 Years Ago
Posts: 1, Visits: 5
I've been trying to get my hands on a 300 dremel for a while, or specifically this; www.bunnings.com.au/dremel-130w-30-piece-corded-rotary-tool-kit_p6280040]
I have a few projects for it but one specifically I am worried about, soapstone or general stone carving, this the 3000 strong enough, I assume it is, I just wanted to check.
Are there any specific bits I should be using for a job like stone carving?
pitonyak
View Quick Profile
Supreme Being
Supreme Being (112 reputation)Supreme Being (112 reputation)Supreme Being (112 reputation)Supreme Being (112 reputation)Supreme Being (112 reputation)Supreme Being (112 reputation)Supreme Being (112 reputation)Supreme Being (112 reputation)Supreme Being (112 reputation)
Posts: 4, Visits: 10
I understand that soap stone is generally about the softest stone and that you can carve it using many of the same tools that you use on wood; for example, a wood rasp. I would expect that any of the high speed cutters would work. That said, I expect that Tungsten Carbide Cutters and diamond to simply last longer.
Be sure that you use suitable eye protection and also wear a mask so you are not breathing in the dust.
I have not done a bunch of carving, but, especially if you will be doing a bunch of carving, then I highly recommend that you get the flex shaft attachment. I was just using mine last night attached to the 4200. Much easier to hold a light shaft than the entire tool.
If this is all that you will do, then consider something like the Dremel 9100 Fortiflex
http://www.dremel.com/en-us/tools/pages/ToolDetail.aspx?pid=9100#.U1sa8TkmfmE
Also available on Amazon
http://www.amazon.com/Dremel-9100-21-Forti-Flex-Stationary-Precision/dp/B00G5R4E9K
I have never used the 9100, only the Foredom, but, at home, I wanted to have access to a standard Dremel and the standard Dremel has a nice warranty so you are probably pretty safe there.
Reading This Topic
