Dremel Message Board
Need Advice Expand / Collapse
Author
Message
Posted 12/22/2007 8:42:22 PM
Forum Newbie
Last Login: 12/22/2007 9:09:10 PM
Posts: 1, Visits: 3
I can't get the collet to close on the bit I'm trying to use. I keep tightening the collet nut but the shaft of the bit seems too small and it can be pulled out easily. Any advice?
Post #3056
Posted 12/23/2007 7:23:47 AM
Supreme Being
Posts: 1,119, Visits: 4,466
I don't know this for sure as I am not there but it sounds like your collet is bigger than your bit. Dremel makes 4 sizes of collets 1/8", 3/32", 1/16", and 1/32". I use the Dremel Chuck Model 4486, in my Dremel, works like a drill chuck. I use the collets in my flex shaft.
But you might check this and see if the collet size is to big which I'm sure it is. Not all kits come with all the collets you can purchase them at your local hardware or Wal-Mart or lots of places were they sell tools. It is Model #4485 package which comes with all 4 collets.
Doug
Post #3057
Posted 12/23/2007 7:32:53 AM
Supreme Being
One thing I forgot check to make sure you have a collet in the tool. Take the nut off and make sure the silver thing with 4 splits in the side.
Doug
Post #3058
Posted 12/24/2007 1:22:40 PM
Junior Member
Junior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior Member
Last Login: 1/15/2009 10:47:21 PM
Posts: 17, Visits: 60
I had the same problem, I then changed to the Demel Chuck #4486 and it worked fine with all sizes of bit shafts.
Post #3064
Posted 12/24/2007 3:00:39 PM
Supreme Being
I use the Dremel chuck on two of my Dremels the flex shaft is the only one I use collets.
Doug
Post #3066
Posted 2/12/2009 5:43:40 PM
Forum Newbie
Last Login: 2/12/2009 5:36:24 PM
Posts: 1, Visits: 4
Doug
I had the same problem with thin bits. I have been using dental bits for some very small work. The smallest collet did not tighten around the dental bit. I changed to the chuck but had the same problem. The chuck did not screw in far enough to tight around the bit. The problem as solved when I took of the collar ust behind the check. I can now tighten down the chuck as far as I want.
Barry
BB
Post #5312
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -6:00, Time now is 8:55pm
Powered by InstantForum.NET v4.1.4 © 2009
Execution: 0.125. 10 queries. Compression Disabled.
