Forum Newbie
Last Login: 1/29/2008 4:04:28 PM
Visits: 3
| Hi. I am new to Dremel, and I am using the tool primarily for miniatures. Here's my question: Is the Stylus compatible with the 4486 chuck? Or do I have to have 4 different sizes of collets on hand to use the drill bits? Thanks!
Junior Member
Last Login: 1/15/2009 10:47:21 PM
Visits: 60
The 4486 works great, I even went out and bought 2 more for the other Dremel tools I have.. You really need it for drilling with small bits. I recommend it very much -JET
Supreme Being
Last Login: Yesterday @ 7:38:26 AM
Visits: 4,677
Im sorry the stylis will only take the collot's and not the chuck.
Doug
Forum Newbie
Last Login: 3/23/2008 3:39:45 PM
Visits: 1
So, what's the story? One reply says yes it will work, the other says no it won't?
TomP
Junior Member
Visits: 60
| The chuck works great for small bits, bottom line.
Supreme Being
Visits: 4,677
I Have alot of Dremel tools but I don't have the stylus sometimes I have made a tool work. On this stuff I would just try it, If it works great if not try something else
Doug
Junior Member
Last Login: 5/22/2008 4:04:05 PM
Visits: 47
| I have a chuck on all my Dremels and they work fine. In using attachments you may have to mount the tool first as the chuck will not clear the hole in the attachment you are using, then put the chuck on the tool. I use a bit size of 3/64 most of the time up to a 1/8 with no probs. Ted!
Ted
