580 table saw
580 table saw
Author
Message
AndyG
View Quick Profile
Supreme Being
Supreme Being (219 reputation)Supreme Being (219 reputation)Supreme Being (219 reputation)Supreme Being (219 reputation)Supreme Being (219 reputation)Supreme Being (219 reputation)Supreme Being (219 reputation)Supreme Being (219 reputation)Supreme Being (219 reputation)
Last Active: 13 Years Ago
Posts: 9, Visits: 19
Greetings.
Q1: Since Dremel no longer makes the 580 table saw, is there an owner's manual somewhere that can be freely shared? Preferabally electronic version that can be downloaded, or emailed? and please share where I can find it.
Q2: Other than ebay, is there a source that anyone knows of for blades for the 580 (specifically 100 tooth)?
Q3: I just purchased a 580 on ebay, and the 40 tooth blade is dull, can anyone share a good source to get blades sharpened?
Thanks in advance,
Andy
AndyG
View Quick Profile
Supreme Being
Thank you very much for the information.
Q1: If I order from the link you provided, do I use the 3-3/8" blade? Q2: The more teeth the cleaner cut?
Q3: Is there a blade that I can use to cut aluminum, and brass, or perhaps the same one?
I will gladly wait for you to send me a copy of the owner's manual. Do you need my email address or how does that work in this forum?
Thank you very much,
Andy
sandy
View Quick Profile
Supreme Being
Supreme Being (4.4K reputation)Supreme Being (4.4K reputation)Supreme Being (4.4K reputation)Supreme Being (4.4K reputation)Supreme Being (4.4K reputation)Supreme Being (4.4K reputation)Supreme Being (4.4K reputation)Supreme Being (4.4K reputation)Supreme Being (4.4K reputation)
Last Active: 6 Years Ago
Posts: 233, Visits: 598
check out www.micromark.com
Rooster
View Quick Profile
Forum Member
Forum Member (41 reputation)Forum Member (41 reputation)Forum Member (41 reputation)Forum Member (41 reputation)Forum Member (41 reputation)Forum Member (41 reputation)Forum Member (41 reputation)Forum Member (41 reputation)Forum Member (41 reputation)
Posts: 1, Visits: 1
I also have an old 580-2 table saw and would love to have a copy of the operating manual when it is available. Thanks.
sorley
View Quick Profile
Forum Member
Forum Member (39 reputation)Forum Member (39 reputation)Forum Member (39 reputation)Forum Member (39 reputation)Forum Member (39 reputation)Forum Member (39 reputation)Forum Member (39 reputation)Forum Member (39 reputation)Forum Member (39 reputation)
Posts: 1, Visits: 60
You can download a copy of the owner's manual as a PDF file here:
http://www.owwm.com/files/PDF/Dremel/580-02.pdf
ACLRAILROAD1943
View Quick Profile
Forum Member
Last Active: 5 Years Ago
Posts: 1, Visits: 15
Primarily as a Service for those who may need accessories for their little Dremel 580 and 580-2 Tablesaws  I fabricate them in my shop, They are listed on Ebay or I can sell direct.I have 1-Miter Gauges w/Extension ,2-Adjustable Rip Fences,3-Back Dust Plates w/Vacuum attachment and bevel lock,4-Saw Sled w/Triangle fence for angle cutting,5-Wrench Set for easy blade changing and 6-A Close Clearance Blade Plate for thin ripping...These are not homemade looking accessories,they are quality designed and made ..I offer 100% Satisfaction Guarantee on Everything I sell..Thanks,Bill,(Retired Seaboard Railroad Shops)
wildbill23c
View Quick Profile
Forum Newbie
Forum Newbie (4 reputation)Forum Newbie (4 reputation)Forum Newbie (4 reputation)Forum Newbie (4 reputation)Forum Newbie (4 reputation)Forum Newbie (4 reputation)Forum Newbie (4 reputation)Forum Newbie (4 reputation)Forum Newbie (4 reputation)
Group: Awaiting Activation
Last Active: 4 Years Ago
Posts: 1, Visits: 1
ACLRAILROAD1943 has some great accessories.  I've already accessorized 1 of my Dremel 580 Table Saws with all of his accessories.  They're top notch, far better quality than the OEM stuff.  I've started accessorizing my 2nd Dremel 580 table saw that I recently purchased off ebay.  So now the fun begins all over again.  The 2nd saw though is the 1st model so it has the 1/4" or 0.25 size motor and arbor shafts so I purchased the cogged belt conversion kit.  Now my saw easily cuts through 1-1/2" thick materials with ease.  Absolutely no belt slippage causing the belt to fly off.
Here's a great link for some more information on the Dremel Table Saw.
Main Link:  http://www.theaerosmith.com/custom3.html
Accessories Link:  http://www.theaerosmith.com/catalog_3.html
I have also attached the PDF version of the Dremel Table Saw Owner's Manual that I have.
Hopefully this helps you out.  I know its a bit late LOL.
Reading This Topic
