Dremel Message Board
Wine Bottle Cork Cutting Expand / Collapse
Author
Message
Posted 4/1/2008 10:36:22 AM
Forum Newbie
Last Login: 4/3/2008 2:44:45 PM
Posts: 1, Visits: 5
I have a 400 series XPR and would like to know if there is an attachment for cutting a wine bottle cork lengthwise so that when cut both pieces are evenly cut and the same size.
Post #3634
Posted 4/1/2008 7:23:31 PM
Supreme Being
Last Login: 2/11/2011 12:18:52 PM
Posts: 216, Visits: 5,072
I would put the cork in the 2500-01 multi-vise, and use the fiberglass enforced 456 cut off wheel.  As far as cutting it perfectly and evenly, you will just have to eyeball it.
Dat's what I tink!
Barry.
If you live to love, then you'll love to live!
Post #3638
Posted 4/1/2008 7:41:38 PM
Supreme Being
Last Login: 2/14/2014 10:35:56 PM
Posts: 177, Visits: 930
kitecork (4/1/2008)
Barry.
DON"T forget eye protection in this case. Glass slivers are bad.
Bruce!
Post #3640
Posted 4/2/2008 9:56:39 AM
Supreme Being
Last Login: 8/1/2009 9:35:07 AM
Posts: 96, Visits: 362
You mentioned cutting a cork.  I think that the other two responders would know better, but you may want to be careful of the speed you use as some of the cutting wheels can cause burning.  If that is the case you may want to simply place the cork in a vice and use a coping saw, etc. to cut the cork.  Again, the other two know a lot more than I do (being a new Dremel owner myself) and burning may not be an issue.
Thanks,
Kurgan
Post #3641
Posted 4/2/2008 11:52:21 PM
Junior Member
Junior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior Member
Last Login: 1/15/2009 10:47:21 PM
Posts: 17, Visits: 60
I would just use a cork screw to remove it from the bottle, it's easier then cutting it in half! -jet
Post #3647
Posted 4/6/2008 7:16:32 PM
Supreme Being
Actually, Kurgen, I do agree.  A coping saw is a great suggestion, and an excellent way to go in this case.  It may even be faster than using a Dremel.
Also, you are limited as to how deep you can cut with a cut off wheel.
Barry.
Post #3660
« Prev Topic | Next Topic »
Forum Moderators: AlyssaCicero
Permissions Expand / Collapse
All times are GMT -6:00, Time now is 4:18pm
Execution: 0.031. 11 queries. Compression Disabled.
