It would be nice to have the ability to plug a small attachement to either a vacuum or a compressor for the purpose of either blowing away or sucking up the dust created while cutting materials such as sheetrock.
I have always thought that the suspicious opening (oval shaped, with a small grove) in the side guards of the Plunge router, the grout remover and multi-purpose cutter attachement looked like it would be a perfect attachement point for a small forced air dust removal snorkle. Essentially it would fit onto that opening and consist of a flexible tube (approx 1/2" diameter) and an adapter that would attach to a standard vacuum tube or a compressor fitting of some sort.
