Forum Newbie
Last Login: 8/23/2009 1:29:21 PM
Visits: 8
I use all dremel attachments and tool bits; I use them continually. I have 4 of the 10 volt units and could not get along without them.
In my opinion, the ez lock is the worst piece of junk that I have ever encountered. If you hold it exactly straight and don't waiver; and don't use much pressure it works pretty well. If you bind it or put any strain on the cut off wheel the center breaks out. I agree that the ez line is a substandard quality item that does not fit the normal dremel service output.
I found that out after purchasing about $100 worth of ez line stuff.
The small screw on wheels work wonders.
Supreme Being
Last Login: Yesterday @ 1:02:04 PM
Visits: 4,682
I agree with that I seldom diss anything from Dremel but this system is a bust as far as I am concerned.
Doug
Forum Newbie
Last Login: 10/16/2009 4:05:26 PM
Visits: 6
i am like the 1st post .. cant afford the ez locl ... the tool is the best .//// i have a flex shaft that is 30+ old .still going.. u wouldnt believe how and what i have used it 4.
have used up many batterys/ wish they would make the lith. 4 the hand held .. there are 3 in my tool box now..tools that is. i need baterys 4 3 of the 4 qp
Forum Newbie
Visits: 8
When I first saw EZ lock I thought it was the best idea in a long time. I immediately purchased about $100 worth of various parts and commenced to use them. They worked fine until I had to get into a tight place and could not keep them exactly straight without any side pressure on them at all; they then commenced to have the center break out of the wheel. Just the tiniest bit of side pressure and the wheel goes; in my opinion it is extremely fragile.
I use the regular reinforced cutoff wheels all the time, and have never broken one.
The 90 degree drive adapter and these cut off wheels are both way too fragile for any amount of real work.
Forum Newbie
Last Login: 12/10/2009 12:38:52 PM
Visits: 14
I like the easy locks.. Very convenient to not have to put your glasses on to change wheels.
-Thanks
Forum Guru
Last Login: 12/17/2009 3:21:48 PM
Visits: 77
| Maperl: I am with you on this.!! Jim
"For almost every problem, there is a DREMEL solution" "When all else fails, read the instructions."
Jim
Forum Guru
Visits: 77
| Folks: The EZ lock discs are designed to cut on their EDGES only. They are not intended for shaping or sanding on their face or back. The discs WILL break if you try to do this. This is a built-in feature so that YOU (the user) do not get hurt. This is clearly spelled out in the product literature that comes with the discs. If you need a shaping/sanding disc, try the #801 or 543 Carbide wheels , or the EZ544 EZ lock carbide wheel.
Jim
Forum Newbie
Last Login: 11/18/2009 1:49:27 PM
Visits: 23
I know the feeling in your hands when trying to chang those darnd little things !And as far as how long the disk last it IS HOW YOU use them ! If you are in to big a hurry you are useing the wrong tool for the job as the Dremel ismade to help you doa job NOT DO THE JOB all at once ! So the lighter the contact with the object you are working the longer the disk will last and the better the job will turn out ! Robert Wyant
robert wyant
Forum Newbie
Last Login: 1/26/2010 5:42:50 PM
Visits: 2
| The easy lock has worked great for me. Much quicker than changing out the mandrel or putting a new tool on the mandrel head. I look forward to seeing more tools coming out with the EZ spindle. As far as tool breakage; I've not found it to be a problem when using the tool as designed and instructed.
