Dremel Message Board
Toenail Shaping Expand / Collapse
Author
Message
Posted 5/4/2006 9:11:05 PM
Forum Newbie
Last Login: 5/7/2007 9:18:41 PM
Posts: 2, Visits: 12
My podiatrist shaped my toenails with a Dremel!  Now I want one, not only for that function, but to remove rust on my outdoor furniture and fence hardware.  I'm thinking of the cordless 10.8 volt Lithium Ion model  Would that be a good purchase, or would the MicroPro be better?  Thanks for advice.
Post #405
Posted 5/5/2006 12:23:51 AM
Supreme Being
Last Login: 1/18/2009 1:14:25 AM
Posts: 104, Visits: 932
If you are out where you do not have power then the 10.8 Volt lithium Ion is your best buy But if power is no problem then the new XPR or the 300 would be the way to go
Post #408
Posted 5/5/2006 8:31:30 AM
Supreme Being
Last Login: 9/23/2007 1:01:15 AM
Posts: 115, Visits: 254
The new stylus would be better suited for your nails. Ergonomically contoured grip and cordless too.
my 2 cents......
RANIE
Post #411
Posted 5/8/2006 12:24:43 PM
Forum Newbie
Last Login: 5/15/2006 5:37:52 PM
Posts: 3, Visits: 7
Hi,
This is sort of a repeat of a post I made a few days ago.  I have some neuropathy in my feet, which means I can't feel much.  One danger of this is cutting flesh when trimming toe nails - which can lead to infection to amputation, etc.  Certainly don't want to go there.
The podiatrist says get a dremel tool.  Ok.  Which one,  and what should be put in the socket.
I assume (didn't get my $ worth from the doc as to details!!) that the proper tool will cut, or grind, the nail (shaping it as mentioned above) without damaging the skin around the nails.  Any experience or advice would be welcome.  Please do not worry about telling me too much!
Thanks, jep
Post #443
Posted 5/12/2006 3:23:34 PM
Forum Member
Forum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum Member
Last Login: 12/4/2008 8:36:56 AM
Posts: 45, Visits: 78
I'd agree.  The Lithium Ion battery makes this a phenom, phono, phino, finom really fantastic buy.  the LI technology makes battery powered tools really viable for everyone.  It's a little more expensive than other battery's but absolutely well worth it.  They last longer - - PLUS - - if you put it in a drawer and don't come back to it for 5 or 6 months - - it's still got the same amount of charge as when you left it.  You can't say that about other battery powered tools.
Good luck
Jefforyj
Post #483
Posted 5/12/2006 3:26:40 PM
Forum Member
I forgot to mention the variable speed of the product and the quiet running sound.  both make it applicable for animals as well.  Our groomer uses it on all the dogs she does and swears by it.
Jefforyj
Post #484
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -6:00, Time now is 3:37pm
Powered by InstantForum.NET v4.1.4 © 2009
Execution: 0.141. 11 queries. Compression Disabled.
