Dremel Message Board
Wanting a Dremel, can't decide on model Expand / Collapse
Author
Message
Posted 7/26/2008 2:48:11 AM
Forum Newbie
Last Login: 7/27/2008 1:48:40 PM
Posts: 1, Visits: 6
I'm trying to figure out what model to choose, either the 7.2 volt cordless model with 50 accessories, or the 10.8 volt model with MORE POWER and 40-60 accessories.
I can deal with less, but I'm not sure how strong the 7.2 volt cordless model is. Could it drill/engrave through/in something like a license plate? I've several small craft ideas and doing something with old license plates is something I've had in mind.
And I want to do this as well,
http://www.instructables.com/id/Swiss-Army-Keys-Key-and-Leatherman-Mod/
Also the 10.8 model isn't at walmart yet, so it would be a while before I could purchase it. (Employee discount is an incentive to buy it there.)
So are the crafts I have in mind doable (in a timely fashion, no hour of drilling for one hole) with the 7.2 volt cordless model or should I wait/hunt-down the 10.8 volt one? And how much is the latter? Seeing as how I can't find a retailer online that has one.
Thanks for suggestions,
Michael
Post #4229
Posted 7/26/2008 7:32:17 AM
Supreme Being
Posts: 1,119, Visits: 4,466
If I was you I would go for the 400XPR its not cordless but it is the strongest Dremel made.
Doug
Post #4230
Posted 7/27/2008 9:41:29 PM
Supreme Being
Last Login: 8/1/2009 9:35:07 AM
Posts: 96, Visits: 362
Mike,
That is a pretty nifty way to store keys. Thanks for the idea and instructions.
With regard to your question, I am in complete agreement with Doug. The 400XPR is the most powerful Dremel and the kit comes with over 75 pieces.
Good luck with whatever decision you make.
Thanks,
Kurgan
Post #4237
Posted 1/9/2009 12:00:19 PM
Forum Newbie
Last Login: 1/9/2009 3:16:21 PM
Posts: 6, Visits: 5
yeah id have to agree with the others although i have the 300 series and have to say that im quite impressed, im using it primarily to do stone carving/engraving and haven't had any problems to date the only thing i noticed is that when i try to set the variable speed to one of the lower settings it either barely spins or not at all, anyone have this problem with the 300 series also?
also for about 25-35$ you could purchase the 200 piece kit separately saving roughly 120$ and it has alot of extra space in it to store anything extra you might purchase as well. but all in all im definitely glad i made these investments, i finally have an artistic outlet yipee
Post #5102
Posted 3/12/2009 8:38:56 PM
Forum Newbie
Last Login: 3/12/2009 9:03:15 PM
Posts: 4, Visits: 56
I have a cordless model, which is only suitable for short time operations and light-duty work.
The battery needs to recharged often.  Having a spare battery is handy.
For continuous use operation, the electric models are the way to go.
A variable speed model is my choice.
Continuous high speed operation, on some materials, will result in damage goods and may render the tool useless.
HS steel bits will burn and ware-out, when exposed to the high speed.
Many tools will fail prematurely, when exposed to the 30-35,000 rpm.
With a variable speed model, adjust the speed control, suitable for the tool being used, and the speed and feed.
Practice on s**** wood, 'til you get the feel for the tool and how to use it effectively.
Post #5478
Posted 11/5/2009 8:31:04 PM
Forum Newbie
Last Login: Today @ 7:41:27 PM
Posts: 5, Visits: 4
actually the 400xpr is retired, so it is the dremel 4000
adel dermal fan
Post #6148
Posted 11/5/2009 8:32:43 PM
Forum Newbie
Posts: 5, Visits: 4
yup i have a dremel 300 and you are right
adel dermal fan
Post #6149
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -6:00, Time now is 9:42pm
Powered by InstantForum.NET v4.1.4 © 2009
Execution: 4.062. 8 queries. Compression Disabled.
