Forum Newbie
Last Login: 7/30/2008 10:07:28 AM
Visits: 6
| I got my Stylus the Christmas before last when it was first stocked at Menard's. I got to use it a couple of times and then broke my back, damaged my sciatic nerve and wasn't able to do much of anything until recently. All that time the Stylus was on the plugged in charger. I picked it up and tested it and it seemed to work just fine except the cutting wheel was broken and I had to get new ones. (Nothing is where it is supposed to be anymore.) I put on the new wheel and then couldn't get the slide lock to slide. Once I got it right, the on switch wouldn't work. I don't know if the problem is the tool or the switches or the charger or something else. I notice the green light blinks for 30 seconds then stops. There was no manual with the Dremel and I figured someone here might know what is happening. I can find one of my other 4 Dremels but I had high hopes for this one. Sleepless
Supreme Being
Last Login: Today @ 7:38:26 AM
Visits: 4,677
I would call customer service that should still be under warranty. If you call them they should be able to send you a new one.
Doug
