Supreme Being
Last Login: 1/15/2010 12:15:03 AM
Visits: 608
Forum Newbie
Last Login: 1/31/2009 5:36:35 PM
Visits: 2
| Clarebear, On my Model 761 Pet Nail Grooming Tool I put the device halfway between Off and Lo and that does the trick for me. I am allowed to continually trim the nail applying consistent pressure until the nail is at the desired length, which usually is about 10 seconds. My pugs don't seem to mind the heat or pressure at that setting. I use the sander that came with the device and have no intention of switching to a bigger or smaller size when I am ready to repace it. As far as holding them is concerned I usually sit on the toilet or a chair and set them in my lap so that my arm is secure around their body (keeping them from trying to escape) while I trim the nails. It also allows me to reassure them that everything is okay while I am using the dremel. Even when I get close to the quick it doesn't cause a problem; they flinch slightly and then I move on to the next nail. I can usually finish all nails on both pugs within 5 minutes. I have had the device since August and I don't think I will ever go back to any other method to trim their nails again. The device continues to work great and getting their nails cut is no longer a frightening experience for my dogs.
Junior Member
Last Login: 2/22/2009 12:07:44 AM
Visits: 20
Junior Member
Visits: 20
Hmmm, I couldn't edit my above post, but what I wanted to add is that the PDF also gives good tips on getting your dog acclimated to the tool.
Supreme Being
Last Login: 1/26/2010 8:37:33 PM
Visits: 406
Yes, that's a good one. Also short and clear. Thanks 'Packrat'
Enrique
Junior Member
Visits: 20
Your link is good also, Enrique, thank you.
Packrat
Forum Newbie
Last Login: 2/7/2009 9:12:22 PM
Visits: 17
| Help! I don't speak Dremel! I started out researching those As Seen On TV pet nail trimmers. Well, it didn't take long to realize that they are junk and I ended up here. Before I invest in the wrong Dremel, I would like your advice. What do I need? I've read this board and I've seen a lot of different model numbers bandied about. I have two B-I-G-G big dogs. One bites her nails (don't ask, she has other emotional problems too) and they are always as sharp are razor blades. This is not a good thing when she steps on you when you are barefoot. My other mutt (and I call them that with deep affection) is even bigger and his nails are quite long. They are so thick that I am not able to cut them with the pet store type nail trimmer. I figure if I get the right tool to do them myself I can save money and his nails will be in better condition. Having the veterinarian do them gets pricey. So, I'm thinking I need something - Powerful, but not too powerful
- Cordless (of course)
- Rechargeable
Your suggestions, please and thank you.
Supreme Being
Visits: 406
Forum Newbie
Visits: 17
| Thanks for the welcome, Enrique! I am thinking that I want something that I can recharge, rather than replace batteries. This Grooming Tool is not rechargeable, correct? I've got a lot of big toes to trim!
Supreme Being
Visits: 406
Well, that an easy one! Why don't you buy a couple of rechargeable batteries and a charger? You won't have to be depending on a single battery manufacturer forever! Can you find anything better than Dremel?
Enrique
