Dremel Message Board
CUT WINE CORKS LENGHT WISE Expand / Collapse
Author
Message
Posted 9/30/2008 5:07:09 PM
Forum Newbie
Last Login: 10/2/2008 12:01:32 PM
Posts: 1, Visits: 4
I can probably figure out a jig for my Dremel 400 XPR.
I want to cut a series of corks in a line of say, six. I have used a band saw in the past, that was still not that good a cut or ease of operation. I was considering a blade that can cut cleanly and easily through approx. 1" corks. I don't see a jig saw blade working well.
Any suggestions are welcome, Thanks, Neil
Post #4542
Posted 9/30/2008 10:14:21 PM
Supreme Being
Last Login: 8/1/2009 9:35:07 AM
Posts: 96, Visits: 362
Neil:
If I were you I would do it the easy way and simply place the cork in a vice (or carefully hold it with your hand) and use a coping saw to cut it in half lengthwise. It is quick, easy and you will have less of a mess to deal with afterward.
If you are going to use a Dremel, you should use one of the cutting wheels, but be very careful of the speed you use. You do not want to burn the cork.
I have been making homemade wine for years and work with corks quite a bit. If I were you I would stick to the coping saw.
Good luck.
Thanks,
Kurgan
Post #4543
« Prev Topic | Next Topic »
Forum Moderators: AlyssaCicero
Permissions Expand / Collapse
All times are GMT -6:00, Time now is 11:55pm
Execution: 0.016. 7 queries. Compression Disabled.
