Junior Member
Last Login: 12/29/2008 6:20:47 PM
Visits: 29
...and one more today.
Junior Member
Visits: 29
Did another one today of my daughter.
Then cut down a cedar tree behind the house and made a frame for it.
Then put a light and switch on the back of it.
Supreme Being
Last Login: Today @ 1:02:04 PM
Visits: 4,682
Great work I love the frame
Doug
Supreme Being
Last Login: 1/15/2010 12:15:03 AM
Visits: 608
I agree with Doug
Did you get the idea for the frame from those modder links?
Also, did you use your Dremel to fashion the frame?
Curt
My Web Site
Junior Member
Visits: 29
| Actually I've built a frame like that before. But I did get the idea for the light from the links. I used my dremel to route the hole for the switch and light.
Supreme Being
Visits: 608
Thank Southerocker
Although I worded the question badly, I did get the answer for which I was looking. Namely, that you were able to adapt the information in the case modder tutorials to your own project.
I was also hoping my silly questions would stimulate those new to Dremel use to ask their own questions because there is a lot of information on what can be done with a Dremel and not as much on the "How To" side.
Thanks for showing us your creations!
Curt
My Web Site
Junior Member
Visits: 29
After some internet searching I did find where I can buy some plexiglass fairly cheap. http://www.estreetplastics.com/Plexiglass_Sheets_Clear_s/21.htm
I want to try my next one with plexiglass and do the LED thing on the side. I'll post the results when I'm done.
Junior Member
Visits: 29
Here's another with plexiglass. I plan on putting led's on the side of this one and then frame it.
Junior Member
Visits: 29
I got the led's put on but I still need to build a frame for it. I used the instructions from here. http://metku.net/index.html?path=mods/multilayer-animation/index_eng2
Here it is without the flash on the camera.
Here it is with the flash.
Here it is with the led's turned on.
