Forum Newbie
Last Login: 12/13/2008 1:19:05 AM
Visits: 4
I purchased the MultiMax this week and what a tool! I bought it mainly for the detail sander portion. This tool is a lot quieter than most sanders I've used and it removes material like a pro. It's going to be my main sander most likely. I've tested the other attachments and discovered that although they will cut through wood it doesn't do as good on hard woods. I had a heck of a time trying to cut through some Brazilian Ebony. The flush cutter works perfectly. Only one thing I'd try to change about this tool is the way you need to switch attachments. It takes a little time changing to the sanding attachment and to change to the cutting and s****ing isn't too bad. All you need to do is loosen the allen screw instead of completely taking it out for the sander. Also I thought it was a bit pricey for tool, $100.00 street price and I saw it go for more on the net. Lucky for me that Home Depot labeled the price incorrectly and I bought it for $49.00. A 50% mistaken mark down. They couldn't charge me the full price because there were 10 on the shelf all for the same $49.00 price. One of their employees messed up. Still I give it an 8 out of 10.
