Forum Newbie
Last Login: 6/20/2009 8:33:22 AM
Visits: 10
| I have a 300 series Dremel, I bought a 231 router table and got the adapter from Dremel. I put on a #654 router bit and ran a soft piece of wood over the bit to cut a groove in the wood. I had the bit set about a half inch up. the groove I cut was about 7 inches long. I stoppped, turned off the Dremel than wanted to cut another groove. When I turned on the Dremel it did not start up. I unscrewed the caps to check the brushes, the springs and brushes will not come out. I think the brushes are burnt up. Did I push my Dremel too hard?
