Using EZ Lock Diamond Wheel
Author
Message
RobinHill
View Quick Profile
Supreme Being
Supreme Being (82 reputation)Supreme Being (82 reputation)Supreme Being (82 reputation)Supreme Being (82 reputation)Supreme Being (82 reputation)Supreme Being (82 reputation)Supreme Being (82 reputation)Supreme Being (82 reputation)Supreme Being (82 reputation)
Last Active: 10 Years Ago
Posts: 2, Visits: 10
I want to cut ~1/2 X 1" slabs from stone using this wheel but have several questions.
Normally water is used with diamond saws. Can water be used with this? Want to immerse wheel in pan of water and use bottom of pan to guide stone to get parallel cut.
I imagine this will be very messy.
Will this hurt the EZ lock shaft????
What speed range should be used with this wheel? Description says not to go over 20000, but this doesnt agree with the speed guide.
wayner
View Quick Profile
Supreme Being
Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)Supreme Being (1.4K reputation)
Last Active: 5 Years Ago
Posts: 82, Visits: 547
For your own safety water and electricity do not mix.  Your motor is not properly sealed for this application and I strongly recommend that you do not try it.
Wayner   Wink
RobinHill
View Quick Profile
Supreme Being
Thank you for your reply and advice.
The practice of drilling in a pan of water is common practice in jewelry and lapidary work as can be seen by the following quote from a jewelry workshop posting
"Put the stone in a container of water and drill the stone in the water. Whatever you do use water to reduce heat and cut down on dust which can be toxic in certain stones like Azurite because of its high copper content.
Use diamond coated drill bits with a rotary tool with a minimum rps of 20,000 rps if you can.
Using the diamond wheel in this case may not even be possible because of the "splatter".  I haven't tried it.
rotarytool
View Quick Profile
Supreme Being
Supreme Being (76 reputation)Supreme Being (76 reputation)Supreme Being (76 reputation)Supreme Being (76 reputation)Supreme Being (76 reputation)Supreme Being (76 reputation)Supreme Being (76 reputation)Supreme Being (76 reputation)Supreme Being (76 reputation)
Last Active: 9 Years Ago
Posts: 2, Visits: 4
wayner (1/25/2009)
Would not using the FlexShaft to reduce the chance of damaging the rotary tool be an option? Hanging the tool above your work station to avoid any dripping.
KevinRenner
View Quick Profile
Supreme Being
Supreme Being (121 reputation)Supreme Being (121 reputation)Supreme Being (121 reputation)Supreme Being (121 reputation)Supreme Being (121 reputation)Supreme Being (121 reputation)Supreme Being (121 reputation)Supreme Being (121 reputation)Supreme Being (121 reputation)
Posts: 5, Visits: 5
Using the flex-shaft, and having the tool plugged into a GFI outlet would pretty much cover any safety concerns. That being said, any water getting into the tool probably wouldn't do it any good.
AlacratStore
View Quick Profile
Supreme Being
Supreme Being (105 reputation)Supreme Being (105 reputation)Supreme Being (105 reputation)Supreme Being (105 reputation)Supreme Being (105 reputation)Supreme Being (105 reputation)Supreme Being (105 reputation)Supreme Being (105 reputation)Supreme Being (105 reputation)
Last Active: 7 Years Ago
Posts: 5, Visits: 5
I purchased the cutter and quick attachment devise and found them easy to install and use. They cut the small pieces of tiles I needed cut with minimal effort and remain ready for many more projects in the future.
www.alacraft.com.au/stickers-cat8
devonlemon
View Quick Profile
Forum Member
Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)
Posts: 1, Visits: 1
When water current use for diamond cutting at what speed water strikes on diamond surface?
RTA Kitchen Cabinets
stellajerome
View Quick Profile
Forum Member
Forum Member (39 reputation)Forum Member (39 reputation)Forum Member (39 reputation)Forum Member (39 reputation)Forum Member (39 reputation)Forum Member (39 reputation)Forum Member (39 reputation)Forum Member (39 reputation)Forum Member (39 reputation)
Posts: 1, Visits: 1
May be some safety measures must be taken in order to avoid any accidents and you should take some advice from experts before doing any creepy thing...
http://www.zippd.com.au
morrisgomes
View Quick Profile
Forum Member
Forum Member (33 reputation)Forum Member (33 reputation)Forum Member (33 reputation)Forum Member (33 reputation)Forum Member (33 reputation)Forum Member (33 reputation)Forum Member (33 reputation)Forum Member (33 reputation)Forum Member (33 reputation)
Posts: 1, Visits: 1
Yeah,some safety measure must be taken in order to make sure that no one is hurt and the process would be taken forward smoothly...
[url=http://www.onbeingablacklawyer.com/wordpress/author/yoland
a-young]Yolanda Young[/url]
Yolanda Young
Reading This Topic
