Dremel Message Board
Screw in brush covers(little plastic ones Expand / Collapse
Author
Message
Posted 2/13/2009 4:23:09 PM
Forum Newbie
Last Login: 2/13/2009 4:19:49 PM
Posts: 1, Visits: 1
Anyone else have trouble with the little blue plastic covers for the brushes stripping out? I have a multi pro that this has happened too and I cannot find replacements anywhere locally.
"Think before you sink!"
Post #5313
Posted 3/24/2009 12:09:09 AM
Forum Member
Forum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum Member
Last Login: Yesterday @ 11:24:59 PM
Posts: 39, Visits: 246
I have had problems similar to this in other tools.
What I did was use light aluminum tin foil (kitchen stuff) as a build up layer. Only because there is very little pressure here involved to holding the brushes in.
One layer is usually enough to tighten up the worn threads.
Do not overtighten, which may have been your cause for stripping the threads.
Teflon tape will work for you as well, and or light copper foil.
Even the tinfoil from  a cigarette pack will work, but it is awful light and would be my last choice.
Do not do this if you have any tool with metal housing. You may have electrical shorting problems.
If it is an all plastic housing and plactic screws you should be safe to go.
Post #5506
« Prev Topic | Next Topic »
Forum Moderators: Hannah at Dremel
Permissions Expand / Collapse
All times are GMT -6:00, Time now is 4:58am
Powered by InstantForum.NET v4.1.4 © 2010
Execution: 0.172. 10 queries. Compression Disabled.
