Rust on Pet Carrier Door
Author
Message
packrat
View Quick Profile
Supreme Being
Supreme Being (254 reputation)Supreme Being (254 reputation)Supreme Being (254 reputation)Supreme Being (254 reputation)Supreme Being (254 reputation)Supreme Being (254 reputation)Supreme Being (254 reputation)Supreme Being (254 reputation)Supreme Being (254 reputation)
Last Active: 10 Years Ago
Posts: 12, Visits: 20
The doors on my pet carriers had become so rusty I am embarrassed to go to the vet's. It finally occurred to me it would be a good Dremel project. I'm using my Dremel 300 with a FlexShaft attached (the 300 is hanging from a Work Station), and a 428 carbon steel brush.
Even though I had read the directions, by the time I started the project I forgot and went a little too fast and didn't angle the brush properly (about 15 degrees). As a result, there was a lot of bristle breakage initially. Bringing the speed down to a "2" and slightly angling the brush for better contact resolved that problem.
It's working great and the doors I've completed look 100% better.
My next project will be the rusty toilet bolts. I'll use my cordless 10.8V for that one.
wdtrnr
View Quick Profile
Supreme Being
Supreme Being (278 reputation)Supreme Being (278 reputation)Supreme Being (278 reputation)Supreme Being (278 reputation)Supreme Being (278 reputation)Supreme Being (278 reputation)Supreme Being (278 reputation)Supreme Being (278 reputation)Supreme Being (278 reputation)
Last Active: 6 Years Ago
Posts: 12, Visits: 37
I also use penetrating oil for "frozen" hardware.Smile
TimothyTFendley
View Quick Profile
Forum Member
Forum Member (31 reputation)Forum Member (31 reputation)Forum Member (31 reputation)Forum Member (31 reputation)Forum Member (31 reputation)Forum Member (31 reputation)Forum Member (31 reputation)Forum Member (31 reputation)Forum Member (31 reputation)
Posts: 1, Visits: 2
You can use foil and coke, I know it sounds strange but it works.Just wad up a foil ball and dip it in coke and then scrub over the rusted parts and the rust will be removed just do it once.
Ventouse Minceur
Timothy T. Fendley
Reading This Topic
