Stabilizing feature
Stabilizing feature
Author
Message
Cutnglue
View Quick Profile
Supreme Being
Supreme Being (329 reputation)Supreme Being (329 reputation)Supreme Being (329 reputation)Supreme Being (329 reputation)Supreme Being (329 reputation)Supreme Being (329 reputation)Supreme Being (329 reputation)Supreme Being (329 reputation)Supreme Being (329 reputation)
Last Active: 10 Years Ago
Posts: 11, Visits: 15
Would like to see a feature that would be an adjustable support behind the oscillating head that would make it easier for consistent height and depth of a cut.  It would need to be a combination height and "rip-fence" concept.
This could be a combo possibly with a similar feature for the powercord-end of the tool which would allow a specified / desired angle of cut to be maintained and smootly cut.
This would allow i.e. resting the tool on a floor surface and cut to raise the baseboard for tile, without getting into drywall, screws, nails, and/or wiring inadvertently, not to mention a nicer face on the cut as well.
Also would allow to undercut at an angle to give room for tucking a wire/cable out of sight under basboard bottom edge without having to remove and rout out on the back side and re-install.
Under certain situations would also allow for simple and tight quarters mitered cuts
The protrusion should be firm enough to maintain settings, yet of a nature to absorb vibrations and slide smoothly on any surface without leaving marks.
It should be flexible/easy to set and lock such that the oscillation does not cause the setting to change once locked into place.
Reading This Topic
