Dremel Message Board
Miter joints Expand / Collapse
Author
Message
Posted 5/31/2009 7:13:00 AM
Forum Newbie
Last Login: 5/31/2009 7:04:25 AM
Posts: 1, Visits: 1
Is it possible to create a miter joint from pieces of trim, using a Dremel attachment? I need to create a small picture frame.
Post #5672
Posted 6/10/2009 8:42:42 AM
Forum Newbie
Last Login: 6/10/2009 8:36:47 AM
Posts: 3, Visits: 7
Chotu,
I don't see why not! I would use a straightedge to draw a line on the flat backside of the trim at whatever angle you want to cut the trim. If you have a steady hand you could follow the line freehand with your Dremel using a standard spiral cutting bit, but I would clamp a straightedge to the the trim to use as a guide fence.
I hope this helps!
Sincerely,
Ron
Post #5692
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -6:00, Time now is 9:43am
Powered by InstantForum.NET v4.1.4 © 2009
Execution: 0.125. 9 queries. Compression Disabled.
