Dremel Message Board
Need the right bit Expand / Collapse
Author
Message
Posted 6/26/2009 7:12:00 PM
Forum Newbie
Last Login: 6/27/2009 11:22:02 AM
Posts: 2, Visits: 3
I'm trying to cut a 3/4 inch hole in the side of my RV.
The siding is light gauge tin, or perhaps aluminum, and behind it is pink insulation, so a standard drill bit will not work very well....
I think the right Dremel cutting bit will work well for this but I'd be happy for your suggestion.
I figure to draw the hole onto the tin and then drill a small pilot or starter hole. Then with the right cutter bit, I should be able to cut along the drawn hole and produce an accurate and smooth hole.
Ideas? Suggestions?
Thanks
Post #5771
Posted 6/26/2009 7:19:13 PM
Forum Newbie
Posts: 2, Visits: 3
Ok, maybe I should have checked this our first. I saw the big chart of the different accessories and it looks like the cutters 9901 - 9904 might do the job.
Does that sound right?
Thanks
Post #5772
Posted 6/27/2009 10:38:12 AM
Supreme Being
Last Login: 10/25/2009 7:27:03 PM
Posts: 116, Visits: 419
My recollection is that the cutters 9901-9904 can leave kind of a rough edge. You might want to try them on an aluminum can etc before tackling the good stuff.
I've used the 409 15/16" cut off wheel for similar projects. After marking out the hole with pencil, I started cutting several pie or wedge shaped pieces across the hole from line to line. By then, the cut off wheel has worn down considerably. When it is 1/2" or smaller I use it to make a small cut on the line itself and the wedge piece drops off. For my projects the final cut edge was covered so I wasn't overly concerned from a "looks" standpoint. Good Luck!
Post #5775
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -6:00, Time now is 11:29am
Powered by InstantForum.NET v4.1.4 © 2009
Execution: 0.156. 9 queries. Compression Disabled.
