Which bit to use on polystyrene
Author
Message
sophisticatedhippie
View Quick Profile
Forum Member
Forum Member (49 reputation)Forum Member (49 reputation)Forum Member (49 reputation)Forum Member (49 reputation)Forum Member (49 reputation)Forum Member (49 reputation)Forum Member (49 reputation)Forum Member (49 reputation)Forum Member (49 reputation)
Last Active: 10 Years Ago
Posts: 1, Visits: 2
My wonderful daughter and son-in-law gave me my second Dremel tool for Christmas 2007, 300-N/25  and I love it.
I have only used it so far doing my own acrylic nails and to shorten my labs nails so I'm very inexperienced with most of the other bits and pieces to it.
I recently bought this bust http://www.firemountaingems.com/details.asp?PN=H201309PK and the space between the earlobe and neck is too close to put an earring through without mangling the earwire.  I was hoping someone here would be experienced enough to recommned which bit to use on polystyrene to scoop out some space on the neck behind the earlobe.  I dont want to darken the area and ruin the bust so of course I would practice on the back first but I dont have a clue where to start as far as which bit.  Any help would be appreciated.
tnsilverleaf
View Quick Profile
Supreme Being
Supreme Being (495 reputation)Supreme Being (495 reputation)Supreme Being (495 reputation)Supreme Being (495 reputation)Supreme Being (495 reputation)Supreme Being (495 reputation)Supreme Being (495 reputation)Supreme Being (495 reputation)Supreme Being (495 reputation)
Last Active: 7 Years Ago
Posts: 19, Visits: 38
Odd, it looks like there should be enough room. The poly on those is usually very thin, from what I've seen. You may be better off carving a bit off the back of the ear, rather than trying to take some from the head. The idea is to get the earring on display, right?
I would suggest something in the 100 series of bits on a lower speed. I cannot say exactly which bit. I don't want to advise one that is too wide or too narrow. You should be able to determine the right one when you go shopping.
Reading This Topic
