Dremel Message Board
Using Dremel on T6 Aluminum Pipe Expand / Collapse
Author
Message
Posted 7/11/2009 12:03:33 PM
Forum Newbie
Last Login: 7/11/2009 9:30:49 PM
Posts: 1, Visits: 4
I want to be able to notch a T6 Aluminum pipe that is 1/4 inch thick. Is this possible using a dremel? And what type of setup do i need. I would imagine i need to secure the tool and somehow rotate the aluminum pipe easily. Any help on this is greatly appreciated. Also what type of tip should i use if i want the notches to be about 1/8 or 16th wide and very shallow.
Post #5805
Posted 7/12/2009 7:04:45 AM
Supreme Being
Last Login: Today @ 12:41:30 PM
Posts: 1,177, Visits: 4,684
Not sure what you are planning to do but the #456 fiberglass reinforced cut-off wheel should do it. Although if I had access to a band saw I would use it. A wood blade will work on Aluminum.
Doug
Post #5807
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -6:00, Time now is 5:18pm
Powered by InstantForum.NET v4.1.4 © 2010
Execution: 0.172. 12 queries. Compression Disabled.
