Forum Newbie
Last Login: 9/29/2009 5:24:32 AM
Visits: 3
I was given this scrollsaw. The motor runs good, cant tell how old it is, Model 1680. any way, The counter balance on the end of the motor shaft had lost the bolt that holds the connecting rod to the lower arm , I do believe is striped out , it wont stay in and there is a terrible vibration about mid speed. I this the counter balancer is striped out and I don't know where to go to get the parts. Please help if any one can! thank you who ever responds to this letter stacey
i'M HAVING TROUBLE GETTING THE BOLT ON THE FRONT SIDE OF THE MOTOR TO STAY IN THE COUNTER BALANCE , WHICH CONNECTS TO THE LOWER ARM.
Forum Member
Last Login: Yesterday @ 7:03:35 PM
Visits: 549
| Looks as if the 1680 is a couple models ago. Your best bet is to call or e-mail custer service and see if they can help. I do have a manual in PDF format I can send you if necessary and it does have a list of parts numbers.
Forum Newbie
Last Login: 12/24/2009 5:34:45 PM
Visits: 3
Will you can go to http://www.grainger.com/Grainger/rp_parts_list.jsp?xi=xi&lastProdSearchCriteria=7140843&mfg=DREMEL&model=1680&info=&desc=16+In.+Variable+Spd+Scroll+Saw&supp=20003595&save=1 / to get the parts list then write down the part info. Then call Dremel if you need a part. It work for me. You should try it.
Forum Newbie
Visits: 3
| Hear is Dremels Phone Number:1-800-437-3635
