Dremel Message Board
Jewlery - Dremel 4000 Expand / Collapse
Author
Message
Posted 10/13/2009 3:49:15 PM
Forum Newbie
Last Login: 10/13/2009 8:57:10 PM
Posts: 1, Visits: 3
****o,
      I would like to understand if Dremel (Dremel 4000) is a good tool to work with Jewlery (polish and cut). I will have to use the fleshaft and woundering if dremel can handle the precision requirements while working with jewlery.
                 Thanks, Marcos.
Post #6074
Posted 10/14/2009 8:06:34 AM
Supreme Being
Posts: 1,119, Visits: 4,466
With a little practice the Dremel 4000 can handle any light duty arts and crafts that you put it too. The New 4000 has the power to run all of Dremel accessories and bits I would love to get one but I just bought the Dremel 400 XPR.
Remember to practice on junk pieces before you start on the project you are going to tackle practice makes perfect.
Doug
Post #6077
Posted 11/1/2009 5:46:00 PM
Forum Newbie
Last Login: Today @ 7:41:27 PM
Posts: 5, Visits: 4
sure you can,but you must use either the flexshaft or detailer's grip. plus you must have very stable hands. finally you need to secure it in a vise or somthing and if you use the flex shaft the put it over your workpiece with a flexshaft stand
adel dermal fan
Post #6131
Posted 11/9/2009 4:48:04 PM
Forum Member
Forum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum MemberForum Member
Last Login: Today @ 12:28:59 PM
Posts: 47, Visits: 64
The DREMEL  tool will do whatever  you want it to do, as long as you put the right bits into it and let  the tool's  speed do the work for you.
You are a jeweller. You will need specialized bits to do the work for you.
See your local rock shop or your findings supplier. I bet that they use DREMEL tools themselves.
Jim
"For almost every problem,
there is a DREMEL solution"
"When all else fails, read the instructions."
Jim
Post #6167
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -6:00, Time now is 8:42pm
Powered by InstantForum.NET v4.1.4 © 2009
Execution: 0.047. 9 queries. Compression Disabled.
