Dremel Message Board
Drilling Holes In Metal For Custom Work Expand / Collapse
Author
Message
Posted 10/30/2009 10:59:32 PM
Forum Newbie
Last Login: 10/31/2009 11:43:53 PM
Posts: 2, Visits: 3
Hi, am new to site and Dremel as well. I am curious as to the potential uses for the tools. I was in Home Depot and purchased the 628 Precision Drill Set for the purpose of drilling holes in metal cards to act as clothing hangtags. I have not purchased a drill yet though, what Dremel do the members of this board recommend? How would I secure the metal in place so that I can drill precisely? Do I need any special attachments?
Thank you,
Cat
To seek knowledge is to desire mediocrity, to seek wisdom is to strive for enlightenment.
Post #6122
Posted 10/31/2009 9:35:24 AM
Supreme Being
Posts: 1,119, Visits: 4,466
About any of the Dremel tools will drill the holes but I am not sure the bits will hold up in metal as they are mostly for wood. You would do better to buy one HS steel bit not over 1/4 size. You can call customer service and talk with them about it.
1-800-437-3635 (Toll Free)
1-262-554-1390
(7AM to 6PM CT Mon to Fri)
Doug
Post #6125
Posted 10/31/2009 9:46:38 AM
Supreme Being
I told you the wrong size for the drill bit its 1/8" size not 1/4"
Doug
Post #6126
Posted 10/31/2009 11:46:26 PM
Forum Newbie
Posts: 2, Visits: 3
Is 1/8" the only size available for metal drilling? Are the 628 bits I purchased only able to be used for wood drilling?
Thank you for the quick reply Don. I appreciate it.
Post #6127
Posted 11/1/2009 8:25:30 AM
Supreme Being
The drill bits to use is 1/32-1/8 you have to use the right collet Nut as far as them drilling metal I am not sure I used one on a piece of steel and it burnt it up but I have used one on aluminium and it done ok
Doug
Post #6128
Posted 11/9/2009 1:44:10 PM
Forum Newbie
Last Login: 2 days ago @ 1:49:27 PM
Posts: 8, Visits: 23
Hi,
I have used a Dremel 400 on it's lowest speed to drill light steel but if you are going to drill hard thick still you need a drill press thhat is made fot thatnot a hobby tool !
robert wyant
Post #6163
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -6:00, Time now is 8:43pm
Powered by InstantForum.NET v4.1.4 © 2009
Execution: 0.109. 9 queries. Compression Disabled.
