Which Dremel is Best?
Author
Message
Laurennnn
View Quick Profile
Supreme Being
Supreme Being (86 reputation)Supreme Being (86 reputation)Supreme Being (86 reputation)Supreme Being (86 reputation)Supreme Being (86 reputation)Supreme Being (86 reputation)Supreme Being (86 reputation)Supreme Being (86 reputation)Supreme Being (86 reputation)
Last Active: 9 Years Ago
Posts: 2, Visits: 4
I have never owned a dremel before and am unsure as to which one I should try.  After reading some reviews, I decided that the 300 series sounded better and sturdier than the 400 series.  Now that the 4000 came out, I wonder if I should try it....there hasn't been enough time for reviews to accumulate yet, so I'd be hoping for the best.  Has anyone used it?  I am going to be using the dremel for sanding, grinding, polishing and drilling metals, primarily sterling silver.  I want something that is likely to last.  Any input?
JimRfromBC Canada
View Quick Profile
Supreme Being
Supreme Being (1.6K reputation)Supreme Being (1.6K reputation)Supreme Being (1.6K reputation)Supreme Being (1.6K reputation)Supreme Being (1.6K reputation)Supreme Being (1.6K reputation)Supreme Being (1.6K reputation)Supreme Being (1.6K reputation)Supreme Being (1.6K reputation)
Last Active: 7 Years Ago
Posts: 64, Visits: 78
Laurie:  I am going to weigh in here, and hope that I can contribute some helpful advice. I have been a DREMEL user since the mid-1960s and I have also been (proudly) a DREMEL product  demonstrator since 1996. And I still AM!!)
Okay. I have not yet seen or used the new  Model 4000. So I cannot/will not comment upon it.
If the 4000 did not exist, I would (and have) advised any of my students to  have bought the 400XPR.  2.0 amp power means lots of rotational power (torque)  at low speed which is good for sanding and drilling.  At high speed, lots of torque means "feather touch and very precise work"
The 400 XPR will do more work under less stress than it's 1.16 amp cousin the 300 series.
Both have brush-type motors and a good warranty. So you won't be chucking your tool out soon.
Whatever tool you buy, make sure you get a Flex Shaft Attachment.
Hope this helps!
Jim
"For almost every problem,
there is a DREMEL solution"
"When all else fails, read the instructions."
Jim
Laurennnn
View Quick Profile
Supreme Being
Posts: 2, Visits: 4
Thanks for the input!  So it's between the 400 and the unknown 4000.
anjawirth
View Quick Profile
Forum Member
Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)
Last Active: 6 Years Ago
Posts: 1, Visits: 1
The Dremel 4000 got pretty good reviews. Looks like the one to go for
http://best-gear.org/dremel-4000-650-120-volt-variable-speed-rotary-kit/
Anja Wirth
Reading This Topic
