Dremel Message Board
Flexi Drive Shaft Expand / Collapse
Author
Message
Posted 11/16/2009 10:00:47 AM
Forum Newbie
Last Login: 11/17/2009 8:01:05 AM
Posts: 2, Visits: 3
I'm not an owner of a Dremel multitool so please forgive this intrusion, but I would like some information from Dremels owners to help me work out how I can attach my Flexi Drive Shaft to my multitool. The manufacturer states that the flexi drive is compatible with most rotary tools, so I assume that this includes the market leader Dremel.
Here's the product:
http://www.silverlinetools.com/index.html?code=794340
This flexi drive screws onto the end of my multitool fine and I assume the multitool chuck grips the inner shaft which has a 3.1mm square-section. But I can't see any way to do the chuck up once it's screwed inside the end fitting of the flexi drive.
I was wondering if a Dremel chuck has a square-shaped grip (mine is round), or whether a Dremel would engage with the square pillar inside the flexi drive in some other way?
So is my multitool different in some way to a typical Dremel, or am I being thick here in how to attach this flexi shaft?
Here's my multitool:
http://www.argos.co.uk/static/Product/partNumber/7112795/Trail/searchtext%3EXTREME.htm
Post #6241
Posted 11/16/2009 11:21:43 PM
Supreme Being
Last Login: 5/17/2010 12:02:40 PM
Posts: 225, Visits: 407
I think that the best way for you to understand that you will need the square drive nut, which seems to be missing in your equipment, is to download the pdf manual of the original Dremel flexshaft:
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00513v-1.pdf
Enrique
Post #6242
Posted 11/17/2009 8:03:34 AM
Forum Newbie
Posts: 2, Visits: 3
Thanks, I thought it might be something like that. I'll have to try to obtain one from somewhere or maybe mod the spare chuck that came with my multitool. Thanks for your help.
Post #6243
Posted 11/17/2009 1:04:41 PM
Supreme Being
Last Login: 7/26/2010 10:35:34 AM
Posts: 1,195, Visits: 4,826
If you call customer service they should send you one at no charge cause one of the squire nuts should have come with it here is the number.
Phone:
1-800-437-3635 (Toll Free)
1-262-554-1390
(7AM to 6PM CT Mon to Fri
Doug
Post #6244
« Prev Topic | Next Topic »
Permissions Expand / Collapse
All times are GMT -6:00, Time now is 7:55am
Powered by InstantForum.NET v4.1.4 © 2010
Execution: 0.109. 9 queries. Compression Disabled.
