looking for info
looking for info
Author
Message
justme
View Quick Profile
Supreme Being
Supreme Being (130 reputation)Supreme Being (130 reputation)Supreme Being (130 reputation)Supreme Being (130 reputation)Supreme Being (130 reputation)Supreme Being (130 reputation)Supreme Being (130 reputation)Supreme Being (130 reputation)Supreme Being (130 reputation)
Last Active: 13 Years Ago
Posts: 2, Visits: 2
Hi..
I'm looking for info.. I plan to make wooden cookie mold/press.
Wondering if anyone has done this, and what type of wood should I use?  Basically, it's similar to a print relief..  I'd be using a square/rectangle  approx size of  3X 2 ,  carve/cut away a design.. then once cleaned, the cookie mold would be given a light coat of olive oil/ veg oil then pressed into cookie dough, when pulled away, the design will remain in the dough.
I imagine you ask why?? I'm trying to replicate (from memory) old European cookie blocks, to make the cookies my Dad had as a child..I have the family recipe, but not the cookie blocks..
Thanks for any help you can offer.Smile
clu1.2
View Quick Profile
Supreme Being
Supreme Being (76 reputation)Supreme Being (76 reputation)Supreme Being (76 reputation)Supreme Being (76 reputation)Supreme Being (76 reputation)Supreme Being (76 reputation)Supreme Being (76 reputation)Supreme Being (76 reputation)Supreme Being (76 reputation)
Last Active: 11 Years Ago
Posts: 2, Visits: 53
I would use and tight grained hard wood that you can find like eastern hard maple.  I would not use open grained wood such as oak because small particles of the cookie batter will stick in it and go rancid on you.  I would not use cooking oil to lubricate the press for the same reason (the oil will go rancid). Use a nut oil and you will be happy.
Ron Ainge
justme
View Quick Profile
Supreme Being
Posts: 2, Visits: 2
Thanks  to both of your replys.  I'm still in the design process. Thanks for the picture too!!Smile
whimmet
View Quick Profile
Forum Guru
Forum Guru (61 reputation)Forum Guru (61 reputation)Forum Guru (61 reputation)Forum Guru (61 reputation)Forum Guru (61 reputation)Forum Guru (61 reputation)Forum Guru (61 reputation)Forum Guru (61 reputation)Forum Guru (61 reputation)
Posts: 1, Visits: 3
For designs you might try looking on ebay and type in the kind of molds you want to make and someone might just have some up for auction that you could get ideas from to make your molds.
BowHunter
View Quick Profile
Supreme Being
Supreme Being (185 reputation)Supreme Being (185 reputation)Supreme Being (185 reputation)Supreme Being (185 reputation)Supreme Being (185 reputation)Supreme Being (185 reputation)Supreme Being (185 reputation)Supreme Being (185 reputation)Supreme Being (185 reputation)
Posts: 5, Visits: 5
BEAUTYFULL PIECE!! What tipe of wood do you used?
BowHunter >>>------------->
HELP!! Hi, I´m looking for some new carbon brushes to my 400 Series XPR rotary tool, but i can`t find the part number from that piece. How do I have to order it? Is it available? How realy long life has the carbon brush with continue use?
Thank`s.
BowHunter
Reading This Topic
