MULTIMAX Door Hinger!
Author
Message
Jonny50979
View Quick Profile
Forum Member
Forum Member (33 reputation)Forum Member (33 reputation)Forum Member (33 reputation)Forum Member (33 reputation)Forum Member (33 reputation)Forum Member (33 reputation)Forum Member (33 reputation)Forum Member (33 reputation)Forum Member (33 reputation)
Last Active: 10 Years Ago
Posts: 1, Visits: 4
I just wanted to share that the MULTIMAX can also be used to rout hinges on new doors and jam using the flat wood cutting blade that comes with the tool. This will save you a heck of a lot of time if your hanging a lot of new doors. I am very surprised Dremel did not think of this. This is a major selling point for this tool. Also the blade has a depth gauge on it so making the perfect depth cut can be accomplished so your hinges sit flush.
John K
View Quick Profile
Forum Guru
Forum Guru (72 reputation)Forum Guru (72 reputation)Forum Guru (72 reputation)Forum Guru (72 reputation)Forum Guru (72 reputation)Forum Guru (72 reputation)Forum Guru (72 reputation)Forum Guru (72 reputation)Forum Guru (72 reputation)
Posts: 2, Visits: 2
what is the maximum depth of the blade?
hawke
View Quick Profile
Forum Guru
Forum Guru (64 reputation)Forum Guru (64 reputation)Forum Guru (64 reputation)Forum Guru (64 reputation)Forum Guru (64 reputation)Forum Guru (64 reputation)Forum Guru (64 reputation)Forum Guru (64 reputation)Forum Guru (64 reputation)
Last Active: 9 Years Ago
Posts: 2, Visits: 1
You can clamp a block of wood or use one of the available guides to set the blade where it needs to be for the cut as well. I've used it for this and it works extremely well provided you can set the blade properly. Free-handed it's not so easy.
My favorite use so far has been replacing a section of crown molding when installing a projector screen flush into a corner. What other tool can cut directly into crown without forcing you to remove an entire section?
wjxtxdy
View Quick Profile
Supreme Being
Supreme Being (93 reputation)Supreme Being (93 reputation)Supreme Being (93 reputation)Supreme Being (93 reputation)Supreme Being (93 reputation)Supreme Being (93 reputation)Supreme Being (93 reputation)Supreme Being (93 reputation)Supreme Being (93 reputation)
Last Active: 8 Years Ago
Posts: 3, Visits: 1
jobs in china   www.mxease.com
jobs in beijing  www.okokokok.cn
jobs in bejing  http://www.okokokok.cn
jobs in china  http://www.mxease.com
Reading This Topic
