Dremel Message Board
How can I use small drill bits with my... Expand / Collapse
Author
Message
Posted 12/30/2009 5:18:36 PM
Forum Newbie
Last Login: 5/9/2010 2:06:39 PM
Posts: 4, Visits: 13
The current chuck (or whatever it's called) on my dremel will not tighten down enough to fit very small drill bits, and I need to use a #68 drill bit (.0310").
Is there some sort of attachment I need to buy?
Thanks a lot for helping!
Post #6421
Posted 12/30/2009 8:17:39 PM
Supreme Being
Group: Banned Members
Last Login: 11/15/2012 8:44:25 PM
Posts: 1,196, Visits: 4,842
.310 is to big to fit the dremel the largest bit it will hold is 1/8" So with what you want to do I would try a regular drill.
Doug
Post #6422
Posted 12/31/2009 10:47:16 AM
Forum Newbie
Hi, thanks for your reply.
I think you misread my post; I said 0.0310", not 0.310".
Post #6428
Posted 1/1/2010 8:11:20 AM
Supreme Being
Sorry I did misread it its called getting old. There is two ways you can do this. You can buy a Dremel chuck model 4486. Or you can buy the collet nut kit model 4485 either one will work. The chuck is like what a drill would have only much smaller. The collet system works you just have to change the collet each time you want to go big or small on the bits.
Doug
Post #6432
Posted 1/2/2010 6:02:00 PM
Forum Newbie
Last Login: 1/6/2010 1:17:13 AM
Posts: 1, Visits: 6
I have an opposite question/problem. I have the standard collet (1/8) and the keyless chuck, but am looking for something that will give me a way to attach 1/4" bits to the unit.
A slightly larger chuck, like the 4486 that handles 1/4" would be perfect. I'll be using the unit at a low speed for polishing mostly, but can't seem to find anything
......Tills
Post #6441
Posted 1/5/2010 6:16:04 PM
Forum Newbie
Thanks for your help; I bought the dremel chuck and it works great!
Post #6451
Posted 5/7/2013 10:48:02 PM
Forum Newbie
Last Login: 5/7/2013 10:39:41 PM
Posts: 1, Visits: 2
Does the chuck really go down to a #68 bit?  The spec says the chuck is for 1/32" to 1/8", and 1/32" is .0315.  When I use the 1/32" collet, a .0310 bit just falls out, no matter how much I tighten it.  I'd hate to invest in the chuck just to discover that there's no good way to secure a #68 bit.  Frankly, I'd like to go down to a #69 bit, but I wonder if that's even possible with a Dremel?
Post #9105
« Prev Topic | Next Topic »
Forum Moderators: AlyssaCicero
Permissions Expand / Collapse
All times are GMT -6:00, Time now is 1:40am
Execution: 0.031. 7 queries. Compression Disabled.
