How can I use small drill bits with my dremel?
Author
Message
DremelN3wb
View Quick Profile
Supreme Being
Supreme Being (124 reputation)Supreme Being (124 reputation)Supreme Being (124 reputation)Supreme Being (124 reputation)Supreme Being (124 reputation)Supreme Being (124 reputation)Supreme Being (124 reputation)Supreme Being (124 reputation)Supreme Being (124 reputation)
Last Active: 8 Years Ago
Posts: 4, Visits: 13
The current chuck (or whatever it's called) on my dremel will not tighten down enough to fit very small drill bits, and I need to use a #68 drill bit (.0310").
Is there some sort of attachment I need to buy?
Thanks a lot for helping!
DremelN3wb
View Quick Profile
Supreme Being
Hi, thanks for your reply.
I think you misread my post; I said 0.0310", not 0.310".
Tillman
View Quick Profile
Forum Member
Forum Member (35 reputation)Forum Member (35 reputation)Forum Member (35 reputation)Forum Member (35 reputation)Forum Member (35 reputation)Forum Member (35 reputation)Forum Member (35 reputation)Forum Member (35 reputation)Forum Member (35 reputation)
Posts: 1, Visits: 6
I have an opposite question/problem. I have the standard collet (1/8) and the keyless chuck, but am looking for something that will give me a way to attach 1/4" bits to the unit.
A slightly larger chuck, like the 4486 that handles 1/4" would be perfect. I'll be using the unit at a low speed for polishing mostly, but can't seem to find anything
......Tills
DremelN3wb
View Quick Profile
Supreme Being
Thanks for your help; I bought the dremel chuck and it works great!
fjbailey3
View Quick Profile
Forum Member
Forum Member (31 reputation)Forum Member (31 reputation)Forum Member (31 reputation)Forum Member (31 reputation)Forum Member (31 reputation)Forum Member (31 reputation)Forum Member (31 reputation)Forum Member (31 reputation)Forum Member (31 reputation)
Last Active: 5 Years Ago
Posts: 1, Visits: 2
Does the chuck really go down to a #68 bit?  The spec says the chuck is for 1/32" to 1/8", and 1/32" is .0315.  When I use the 1/32" collet, a .0310 bit just falls out, no matter how much I tighten it.  I'd hate to invest in the chuck just to discover that there's no good way to secure a #68 bit.  Frankly, I'd like to go down to a #69 bit, but I wonder if that's even possible with a Dremel?
Reading This Topic
