Squeak and smell from new 200 series
Author
Message
garagebeater
View Quick Profile
Junior Member
Junior Member (21 reputation)Junior Member (21 reputation)Junior Member (21 reputation)Junior Member (21 reputation)Junior Member (21 reputation)Junior Member (21 reputation)Junior Member (21 reputation)Junior Member (21 reputation)Junior Member (21 reputation)
Last Active: 9 Years Ago
Posts: 1, Visits: 4
****o,
Last night I bought a new 200 series Dremel to grind off a tack welded-on nut (15mm) and knew I'd have many other future uses for it. I also bought a package of metal grinding discs.
At first I'm not entirely sure I was using it correctly. I wasn't pushing it or putting any weight on it but I managed to set two of the discs out of balance. The third disc I used stayed in balance even though I cut over twice as much with it than I did with either of the previous discs, which is why I think I must have been doing something wrong with the first two. When I was taking off the disc, I noticed that as I turned the collar it was squeaking as I turned it unlike when was putting on the discs it was silent. I tightened the disc on again and put it on the low speed (15,000 rpm) and noticed it sounded somewhat different than when I had it on low before I had ground anything; no sound difference was noticeable at the higher speed (35,000 rpm) Also I noticed it was emitting an unpleasant smell that I had dissmissed as simply the smell of ground metal as I was grinding.
Is this sound difference / smell of any importance? It was about 20 degrees in my garage where I was working if that has any importance.
Reading This Topic
