Mulit-Max Sandpaper options
Author
Message
Jengle
View Quick Profile
Forum Member
Forum Member (35 reputation)Forum Member (35 reputation)Forum Member (35 reputation)Forum Member (35 reputation)Forum Member (35 reputation)Forum Member (35 reputation)Forum Member (35 reputation)Forum Member (35 reputation)Forum Member (35 reputation)
Last Active: 9 Years Ago
Posts: 1, Visits: 2
I have found the multi-max a great tool so far.  My only gripe is that I have to buy a variety pack of sandpaper when I only need 240 grit.  What are my options here?  Should I buy a new sanding pad and shave off the hook/loops so I can use stick-on paper?  What have others done?
Thanks!
Jeff in Lincoln
sandy
View Quick Profile
Supreme Being
Supreme Being (4.4K reputation)Supreme Being (4.4K reputation)Supreme Being (4.4K reputation)Supreme Being (4.4K reputation)Supreme Being (4.4K reputation)Supreme Being (4.4K reputation)Supreme Being (4.4K reputation)Supreme Being (4.4K reputation)Supreme Being (4.4K reputation)
Last Active: 6 Years Ago
Posts: 233, Visits: 598
I bought a supply of 6" or maybe 7" circular hook & loop paper in the grit I needed. Traced 3 sanding pads onto each sheet (edges abutting as much as possible) cut them out and had myself a good supply of my most needed grit paper. I don't recall using a 60 grit on my Multi-max!
Reading This Topic
