Multi Max praise
Multi Max praise
Author
Message
mickey.608
View Quick Profile
Forum Member
Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)Forum Member (37 reputation)
Last Active: 9 Years Ago
Posts: 1, Visits: 3
Recently I purchased the multi max to be used to cut sheet rock and to cut wood base and trim. I do wall repair after new tubs and showers have been installed in older houses.This tool quickly cuts sheet rock without cutting through the moisture barrier on insulated walls. It creates less dust and mess than a saws all. If I have to do any trimming or if I have to cut out any areas in the sheet rock this tool saves me time and work. It is also great for trimming wood base when you install new heat vents or cold air returns. You cut the base in place without having to remove it. The Multi Max is worth every penny that I paid for it.
BobT
View Quick Profile
Forum Guru
Forum Guru (52 reputation)Forum Guru (52 reputation)Forum Guru (52 reputation)Forum Guru (52 reputation)Forum Guru (52 reputation)Forum Guru (52 reputation)Forum Guru (52 reputation)Forum Guru (52 reputation)Forum Guru (52 reputation)
Posts: 2, Visits: 2
I bought the MultiMax to do sanding around the spindles of a porch railing. What a time saver!! It gets into corners I was having difficulty getting to. I bought the metal cutting blade and have used it a lot also. Great tool. Smile
RobertJGutheim
View Quick Profile
Supreme Being
Supreme Being (1.3K reputation)Supreme Being (1.3K reputation)Supreme Being (1.3K reputation)Supreme Being (1.3K reputation)Supreme Being (1.3K reputation)Supreme Being (1.3K reputation)Supreme Being (1.3K reputation)Supreme Being (1.3K reputation)Supreme Being (1.3K reputation)
Last Active: 8 Years Ago
Posts: 64, Visits: 698
My dad and I picked up a Multi-Max last year over LAbor Day weekend since we needed a tool with it's capabiliities and it's a good tool. In fact we bought a tool made by their Parent Company for our other house (Cordless though) and I can say this much. IF you're doing any extensive work you're better off with a corded model. I had reason a few weeks ago to order the two 1 3/8 blades for the Multi-Max after running into a situation where we needed a blade that was longer then what we already had for the application we were doing.
Beth at Dremel
View Quick Profile
Supreme Being
Supreme Being (5.5K reputation)Supreme Being (5.5K reputation)Supreme Being (5.5K reputation)Supreme Being (5.5K reputation)Supreme Being (5.5K reputation)Supreme Being (5.5K reputation)Supreme Being (5.5K reputation)Supreme Being (5.5K reputation)Supreme Being (5.5K reputation)
Group: Administrators
Last Active: 4 Years Ago
Posts: 229, Visits: 4.3K
We're happy to hear that many of your are pleased with the Multi-Max. Please continue to share your stories, uses for the tools and more. We appreciate learning from you.
Thanks!
-Beth at Dremel
Blake
View Quick Profile
Forum Guru
Forum Guru (54 reputation)Forum Guru (54 reputation)Forum Guru (54 reputation)Forum Guru (54 reputation)Forum Guru (54 reputation)Forum Guru (54 reputation)Forum Guru (54 reputation)Forum Guru (54 reputation)Forum Guru (54 reputation)
Posts: 2, Visits: 2
Just got my tool this weekend to help installing wood floor. This tool is everything advertised. Went right through jams, we even used it to remove some tile (very slow, wrong tool) but it helped. I also have a 4000 and the entire kit, when you need precision, go to Dremel. Just joined, great tool
Time to tear somethin' up!
Reading This Topic
