bit is stuck in dremel, locking button not sufficient
Author
Message
iamsteamboat
View Quick Profile
Forum Member
Forum Member (39 reputation)Forum Member (39 reputation)Forum Member (39 reputation)Forum Member (39 reputation)Forum Member (39 reputation)Forum Member (39 reputation)Forum Member (39 reputation)Forum Member (39 reputation)Forum Member (39 reputation)
Last Active: 9 Years Ago
Posts: 1, Visits: 6
i can't help but think that this question has been posted before, but i can't seem to find anything after an hour or so, so here goes. i was using my friend's (of course) dremel to remove grout, and now the bit is stuck in the tool. i have tried depressing the shaft lock button but the amount of force necessary to loosen the collet nut is greater than what i can apply on that button, and the whole assembly turns. how can i remove the bit? is there a point i can clamp on the dremel to lock the shaft instead of using the button? would it be possible to pull the bit out with brute force?
Reading This Topic
