Everything Dremel
Everything Dremel
Author
Message
markamatte
View Quick Profile
Forum Member
Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)
Last Active: 9 Years Ago
Posts: 1, Visits: 3
My Dremel has overcome everything I've thrown at it.  Drilling stones/gems, cutting rebar/steel bars, carving wooden rings, and making custom picture frames.  I even got a call from a general contractor friend, who had heard some of my 'Dremel stories', asking to borrow my Dremel and my services.  He had installed cabinets and forgot to remove a 3 inch strip of plywood from the bottom...this piece of wood kept him from installing the base plate...and could not reach the strip with any saw he owned.   With less than 4 inches of clearance, and the angle, the Dremel itself would not fit under the cabinet...so I used a circular blade and the flex shaft to remove the strip in about 30 seconds.  Afterwards, he explained that he 'thought' he had every cutting tool necessary to build a house.  The Dremel kept him from having to un-install the cabinets...he purchased his own later that afternoon.
Mark A. Matte
Reading This Topic
