400 XPR Case w/4000 Tool
Author
Message
markheus
View Quick Profile
Forum Guru
Forum Guru (59 reputation)Forum Guru (59 reputation)Forum Guru (59 reputation)Forum Guru (59 reputation)Forum Guru (59 reputation)Forum Guru (59 reputation)Forum Guru (59 reputation)Forum Guru (59 reputation)Forum Guru (59 reputation)
Last Active: 9 Years Ago
Posts: 1, Visits: 4
Hi, does anyone know if the new 4000 tool will fit in the case for the 400 XPR? My old dremel was stolen and I bought the new 4000 as a replacement but I really don't like the style of the new case.
jack0458
View Quick Profile
Supreme Being
Supreme Being (544 reputation)Supreme Being (544 reputation)Supreme Being (544 reputation)Supreme Being (544 reputation)Supreme Being (544 reputation)Supreme Being (544 reputation)Supreme Being (544 reputation)Supreme Being (544 reputation)Supreme Being (544 reputation)
Last Active: 6 Years Ago
Posts: 22, Visits: 43
I just got a 4000 because my 400XPR burned up.  The 4000 was a warranty replacement.  When I got the 400XPR I got the set with flex shaft, planer, multi-saw and other stuff.  It came in a case that held all the tools.  It also holds 4 of the accessory kit boxes.  Really a great case.  The 4000 does fit in it but it doesn't match the molding since the shape is different than the 400XPR which is not problem at all.  I would recommend this case to anyone even if you don't have or need the other attachments.  I don't have the case that would have come with the 400XPR tool itself so I don't know if the 4000 will fit in it.  I just wanted to say if you need a case for the 4000 and the one you have doesn't work well, you may want to consider the case I mentioned.
Jack
Reading This Topic
